Overdrive "OFF" light blinking???
Old Jul 3, 2011 | 01:46 PM
TeamMudd's Avatar
TeamMudd
Originally Posted by Mark Kovalsky
Those codes won't come up if you read the codes at an auto parts store. They are not capable of reading transmission codes. You need someone with a high end scanner, and the auto parts stores don't use them.
"IF" the check engine light is on, then YES a generic scanner will give you a code. BUT also i do agree that it won't give you a "specific" code. it will more than likely give the same on that mine came up with, a P0720, which is just a general problem code for a transmission malfunction.
if the check engine light is NOT on, then yes you'll need a more in depth scan tool to retrieve the codes.
hdbagger
May 17, 2017 08:48 PM
tjc transport
New Jersey Chapter
232
Jul 2, 2016 09:12 PM
Mtnhermit
Apr 30, 2016 12:57 AM
Osiyo59
20
Apr 20, 2014 03:41 PM
go2toa
18
Nov 24, 2005 04:46 PM
