Swapping Trannies
Old Mar 28, 2003 | 05:19 AM
Adel_F150's Avatar
Adel_F150
Swapping Trannies
Okay,
I need help. I have a 1988 F150 w/300 4.9L 6 cyl. I have the 5speed Mazda tranny that has no reverse or overdrive. The engine has about 213,000 miles on it but runs like a sewing machine.
I want to pull the manual transmission out and put an AOD in it.
The AOD is coming out of a merc marquis and was told that it would bolt up to the 4.9L since it is coming off of a 302.
What do I need to do to swap it out?
i.e., Driveshaft, Trans mounts, etc....
I do know that automatic columns are very few and far between here where I live, however, I thought about using a Ford Aerostar Minivan Automatic Floor shifter since they are cable actuated.
Any thoughts or suggestions would be greatly appreciated.
Old Mar 28, 2003 | 02:56 PM
Adel_F150's Avatar
Adel_F150
Swapping Trannies
Okay, I really need some help with this one.
Any help out there?
Old Mar 29, 2003 | 07:38 AM
pfogle's Avatar
pfogle
Swapping Trannies
crossmembers, flywheel, driveshaft, PM steve83 he could give you a better idea.
Old Mar 30, 2003 | 06:14 PM
92f150I6's Avatar
92f150I6
Swapping Trannies
If the auto trans yo are going to swap in is electronicly controlled, you may have computer problems.
Old Mar 30, 2003 | 06:58 PM
carrier's Avatar
carrier
Swapping Trannies
I have a few parts laying around that might be able to help you, I should have a crossmember and a column, maybe a driveshaft - send me an email and maybe I can help?
Old Mar 30, 2003 | 07:37 PM
DoubleA's Avatar
DoubleA
Swapping Trannies
You'll need the flywheel for a 300, back plate, column (you will really only need the shifter and brackets, the column itself is the same and the auto shifter, cable and brackets can be added to your column, auto crossmember, driveshaft, TV cable, starter.
You can do a search under transmissions, and my name, I did this swap and gave some descriptions there.
if you lost OD and reverse the shift fork or something simple might have failed and be an easy fix.
Old Mar 31, 2003 | 12:48 AM
steve83's Avatar
steve83
Swapping Trannies
DoubleA
His '88 column is not like the '92-96 column - he can't add the shifter to it. And autos don't use a flywheel - just a flexplate.
92f150I6
The AOD isn't electronic. It's controlled strictly by the shift lever and the TV cable.
Adel_F150
While a car AOD will bolt up to your engine, your t-case won't bolt up to IT. You need either a 4WD transmission, or you'll have to have the GM AOD rebuilt into a 4WD. I have a tail housing, but not the shaft. You could probably make the floor shifter work, but I'd expect it to be a lot more trouble than finding an auto column to swap in. I also have several crossmembers & an AOD trans mount.
