Hot or Cold???
Old Jun 27, 2011 | 11:43 PM
mueckster's Avatar
mueckster
Hot or Cold???
For those who have run a compression test on your cylinders, did you do the test when the engine was hot or cold?
I am going to replace my valve springs and seals this weekend. I am installing the Comp Cam 910's and .030" shims and using OEM Ford seals. I have a diesel engine compression tester and thought that I would run the compression, for grins, before and after the install. Not really expecting a change. I have built a valve spring compressor tool that bolts to the lower rocker arm pedestal bolt hole. Cory (Ziggy) sent me the head and spring dimensions needed to fabricate the tool. Thanks, Cory! The tool is patterned after the tool that Rotunda makes for Ford. Hopefully, it will do the job fine and get into the tighter confines of the passenger side. I am going to post up pics and document the VS install. Frank (Franko72) will be coming over Saturday to lend a hand in this project. Please rep these guys when you can.
Old Jun 28, 2011 | 01:15 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Good question. I've got a tester here also, need to run a test when the truck is running again.
Old Jun 28, 2011 | 05:38 AM
Franko72's Avatar
Franko72
Molon Labe
Roland IIRC I read a thread here that said to test while warm. Although I'm sure it will be easier on our hands to check it while the engine is cold...
I got your voicemail late last night, but my phone never rang (stupid smart phone....)
See ya saturday.
Old Jun 28, 2011 | 06:51 AM
ChunderDownUnder's Avatar
ChunderDownUnder
Will be doing the same on my engine for the first time as well Roland. Pics and tips will be muchly appreciated.
Old Jun 28, 2011 | 07:36 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Sounds like a fun time Saturday. Good of you to help Frank.
Find all the tricks on doing this Roland, for when we do mine.
Old Jun 28, 2011 | 08:05 AM
mueckster's Avatar
mueckster
See ya saturday.
I did read the same thing. My thoughts too about working on a warm engine. The Texas heat is bad enough.
Don't feel bad. My phone has done the same thing. I've had to shut it down and reboot to remedy it.
It will be. It will be great to see Frank again. We haven't had a chance to meet up since he returned to Texas.
I don't know about tricks, but I kinda have plans on how to do it. If my VS compr tool does its job properly, things will go along smoothly.
Here are pics of the tool (before I painted it; the painted pics would not upload). I know y'all wouldn't believe me without them.
Name:  7.3 VS Compr a.jpg
Name:  7.3 VS Compr b.jpg
Name:  7.3 VS Compr.jpg
Old Jun 28, 2011 | 08:47 AM
milleroutdoors's Avatar
milleroutdoors
Roland, good project, look forward to hearing how your new tool works.
Old Jun 28, 2011 | 08:51 AM
miller_feed
Looking forward to see how it works. Thats a cool tool.
