quarter panel replacement
Old Jun 27, 2011 | 10:50 PM
NuMex75's Avatar
NuMex75
so i pulled a quarter panel off of a parts truck I bought a while ago to fix my dented front quarter panel. the truck is painted the same with similar sun wear so it should look right when I get it on there.
This panel had some kind of seal/ weather stripping between it an the top piece it was mounted to ( for vibration?). do i need to put some kind of buffer to keep it from rattling or will bolting it straight on be ok? Im kinda new to body work so Im just looking for tips before i tear the dented one off my truck and replace it.
Any other tips would also be appreciated.
Old Jun 27, 2011 | 11:16 PM
HIO Silver's Avatar
HIO Silver
More correctly, a "front quarter panel" should be referred to as a fender. Fenders are removable whereas the term "quarter panel" is normally used to describe the rear sides of the body shell....think of the term "hind quarters".
I believe the seal/WS you are referring to is the butyl caulk used to cushion mated surfaces that are bolted together.. vibration? Sure it works for that. I figure it also prevents squeeks, groans, and creaks.
It comes in tube but is also available in strips from 3M.. sorta likea box of licorice. IIRC, a box of is like $10 and can last forever. I also use it to fill cinch nuts on emblems and as a sealer around firewall penetrations in places where there is no grommet. It's maleable like bubble gum but isn't as sticky. NAPA, Oreilly, and Autozone all carry it... just ask for "3M strip caulk" and the knowledgeable ones will know what you are talking about.
Old Jun 28, 2011 | 09:20 AM
NuMex75's Avatar
NuMex75
thanks. ill pick up some of that 3M today so i can put the fender on tonight. on the parts truck i just unbolted the fender and snaked it out without removing the bumper or grill assembly, but I imagine this has to be done to install it correctly.
