brake problem?
Old Jun 27, 2011 | 10:44 PM
FordOwnerJoey's Avatar
FordOwnerJoey
brake problem?
When im driving, if the truck is facing usually facing down hill, the brake pedal moves forward and gently applies the brakes.
I thought it could have been a couple of things:
1-air in the brake lines
2-too much fluid in the master cylinder causing an air bubble and causing vacuum problem
I just got done bleeding the front brakes and adjusting the fluid level in the master cylinder. It still will gently apply the brakes....
as far as i can tell its just the front brakes applying because im pretty sure the rear shoes are worn out, any help?
Old Jul 3, 2011 | 10:39 PM
FordOwnerJoey
does anyone know what this could be from? possibly the whole master cylinder or could there still be air in the brakes lines?
Old Jul 3, 2011 | 10:59 PM
Edgethis's Avatar
Edgethis
Well the brake pedal is a lever. If you dont wanna gradually slow down then just stomp on the pedal.
Old Jul 4, 2011 | 06:43 AM
Lazy K's Avatar
Lazy K
Check that the pedal return spring is good.
May also be a bad booster.
Skyforum
16
Jun 14, 2018 09:19 PM
fl-mitchells
16
Mar 15, 2013 01:43 PM
U-HIGH75
Aug 19, 2012 06:25 PM
shinew
Jul 21, 2007 03:13 PM
tonysquirrel
Jul 25, 2004 04:59 PM
