Ready for 2k Primer
Old Jun 27, 2011 | 08:07 PM
v8xploder's Avatar
v8xploder
Ready for 2k Primer
My panel is fishished and im ready to spray my 2k high build urethane primer over my bare metal and filler work. I plan on using a 2k sealer over the primer when im done sanding.
After I spray 2 coats of 2k primer, should I fishing sanding with 320 then 400 grit? I have read some people finish with 600? Also should my first coat be a light coat then the second be a medium/wet coat?
(by the way im only fixing a dent that was in our commuter car, not a show car, just so you all know that much)
Thanks!
