arc/stick welders, need some help
This one is straight down. Seems a little dark, sorry.
This is from the side. The red arrows are areas of concern to me. Seems to me I'm having undercutting. I've tried different amps and stick angles but I keep getting this crap on the weld toe.
The other side.
I'm getting good penetration in my welds (I think). I stuck two 1/4" plates together, just gaped and burned no bevel or root pass, fill pass or cap pass. I just wanted to see about the penetration of my welds. I could not break the weld or even bend it. Penetration was a little over half the thickness of the plate (I cut through the weld to check).
All in all I don't think I did too bad for my first day at it. I'm still hoping for some advice so I can get better.
Thanks,
Buck
I have gotten much better and burned about 1/4 a box of sticks. I have much better control of the stick and my welds look so much better then the ones I posted. I look at those pics and compare that to what I'm welding now and think the first ones suck. lol My weld puddles are much more uniform and closer together now.
I had some undercutting problems when I started horizontal beads. A little digging online I found my answer. Changed my stick movements from )))) to UUUUU and problem almost completely went away. Ran a few more beads and a couple of sticks and the horizontal beads look great too.
It's been a learning experience, but a fun one.
If you have undercut on one side that means your not holding the rod vertical.Google Image Result for http://www.tpub.com/content/construction/14250/img/14250_144_2.jpg
