1997 Explorer Possible Electrical Issue
Old Jun 27, 2011 | 11:10 AM
kailor's Avatar
kailor
My brother has a 1997 Explorer that is having electrical issues. His car acted dead so I jumped it off. After removing the jumper cables, he turned on his headlights and the car died. Next time, After removing the jumper cables, he turned on his AC and the car died. If the jumper cables remain connected, his car continues to run whether he turns on the headlights or AC. His battery is 2 weeks old. His alternator is 1.5 months old. Also, with his car running and the jumper cables not connected, we removed the positive battery cable and the car kept running so we don't believe it is the alternator.
Any suggestions/help is greatly appreciated.
Keith - member of Expedition Forum.
Old Jun 27, 2011 | 01:00 PM
shorod's Avatar
shorod
Do you have a multimeter so you can make some basic measurements? Just because the battery is new does not mean that it cannot be defective. But, before condemning the battery, you need to make sure the connections to it are clean and tight. Even though it's not recommended with a modern computer-controlled vehicle to disconnect the cable from the battery to test the alternator, that likely confirms that the other end of the battery cables are clean and tight. However, if you didn't turn on the lights or A/C, that still doesn't confirm the alternator is able to supply enough current to keep the charging system going. A few quick measurements with a multimeter will answer a lot of questions.
-Rod
Old Jun 27, 2011 | 01:08 PM
senix's Avatar
senix
Complete charging system diagnosis.
You can get one for free at napa. They will hook it up to your explorer. You start the thing and they will test alternator and battery.
One or both maybe bad.
Old Jun 27, 2011 | 01:45 PM
kailor's Avatar
kailor
Thanks for the quick responses. Both terminals are clean and tight.
Old Jun 27, 2011 | 05:45 PM
aquanaut20's Avatar
aquanaut20
Use a meter and quit guessing... Philip
Old Jun 27, 2011 | 07:52 PM
kailor's Avatar
kailor
Thanks aquanaut20!
Old Jun 28, 2011 | 06:53 PM
87 XLT's Avatar
87 XLT
A quick look at the charge circuit wiring diagram would tell you to check mini fuse 6. It's labeled "Generator/voltage regulator" It's under the hood in the power dist box.
Old Jun 29, 2011 | 11:03 AM
kailor's Avatar
kailor
My brother's 2-week old battery was faulty. Thanks.
Science1974
Oct 17, 2014 08:51 AM
69jwatson
Dec 26, 2012 06:31 PM
msfprobass
1978 - 1996 Big Bronco
Jul 30, 2012 02:18 AM
Old93junk
General Automotive Discussion
20
Apr 3, 2009 08:23 PM
lyoncoeur
1983 - 2012 Ranger & B-Series
Aug 7, 2003 01:06 AM
