I recently posted a message about a EGR problem. Big1 said that he cleaned a filter to clear his check engine light. He said that the filter was inside a electrical connection on the front right (facing) fender. What does that connection look like. I saw a connect that came from my PCV valve. The connect had a round casing with it. It looked like it may have a small filter in it, but I could not open it. Futher down from that connect was a round cylinder with an electrical connection with it also. Can you Help?
hey jhdanieals do you have a repair manual ..if you do just look in side and see if you can trace it to the problem to pin point the area.. another way i would is go to the dealer and explain to them the problem and go from there. i wish i could be more help as i never had this kind of thing happen to me and if i did i would be glad to walk you through it.. good luck
