Offroad & 4x4
welding "9rear
Old Mar 27, 2003 | 09:48 PM
ba 302's Avatar
ba 302
welding "9rear
has anyone ever welded the spiders on a 9" rear is it easy and how is it for everyday uses?
Old Mar 27, 2003 | 09:55 PM
Ryan50hrl's Avatar
Ryan50hrl
welding "9rear
you won't want to do that for everyday use...look into a locker instead.
Old Mar 27, 2003 | 10:07 PM
ba 302's Avatar
ba 302
welding "9rear
thanks for the replay so what kind of locker I'm looking for full time posi and also how hard is it to put one in.
Old Mar 27, 2003 | 11:08 PM
Ryan50hrl's Avatar
Ryan50hrl
welding "9rear
well detroit locker is about the strongest you can get. and if you don't mind a bit of a rough ride through corners if your gassing it...you'll be fine.
Old Mar 28, 2003 | 07:40 AM
72f100's Avatar
72f100
welding "9rear
Why not buy a mini spool? You can do the whole job for $50 including the spool and all the gear lube and gaskets to finish. W/ a spool you don't have that nasty backlash and all that engaging/dis-engaging that you get w/ a detroit. Not to mention you could put in a rear mini spool and a front lock-rite for less than the price of one detroit.
Old Mar 28, 2003 | 08:37 AM
ba 302's Avatar
ba 302
welding "9rear
the mini-spool is a great ideal that would give me full posi right.
Old Mar 28, 2003 | 09:07 AM
KJKozak2's Avatar
KJKozak2
welding "9rear
Absolutely! Here's a picture of a mini-spool next to the spider gears and the carrier. That mini cost me $26 new from e-bay, including shipping. I installed it myself and it wat the first time I ever saw the inerts of a dif.
Kevin K.
Old Mar 28, 2003 | 09:16 AM
ba 302's Avatar
ba 302
welding "9rear
that is a great pic I'm sold thanks for all your help does e-bay carry alot of these spools is that my best place to look first or best bet is at the local parts store?
Old Mar 28, 2003 | 09:42 AM
KJKozak2's Avatar
KJKozak2
welding "9rear
I see these often on e-bay. They may not be the "best on the market", but mine hasn't failed yet and I beat the crap out of it on the trails.
Some things you should know about mini-spools before you put one in. They give you a solid rear axle so your <a href="http://service.bfast.com/bfast/click?bfmid=37919709&siteid=39251846">tires </a>will turn at the same speed around corners. Meaning one tire will skid. If you're on ice/snow, this can be bad. So, you'll have to get used to cornering in these conditions.
Also, you'll have to count the splines on your axle so you get the right spool. You'll either have 28 or 31. Mini-spools can be hard on the axle splines, too. When you turn, all of the torque is on the splines and the spool. I'm not saying you'll wreck the axles, just that they will be more stressed than normal.
Also, see if you gan get the "hardened" pin. That's the pin that goes thru the mini-spool and the carrier, holding the two together. I used the pin from the spider gears, but plan to get the better one someday, just in case.
Hope this helps!
Kevin K.
Old Mar 28, 2003 | 12:55 PM
fordmaniac21's Avatar
fordmaniac21
welding "9rear
you will like the min i spool. i have mine in for about a year and it kicks butt in the mud and on the trial. <a href="http://service.bfast.com/bfast/click?bfmid=37919709&siteid=39251846">tires </a>wear a little faster with it in but it is well worth it. i bought mine on ebay for under 25 bucks incuding shipping and it took about 2 hours to install from start to finish.
Old Mar 29, 2003 | 09:17 PM
ba 302's Avatar
ba 302
welding "9rear
thanks alot guys for your help with this I'm on goin get one as soon as possable and slam it in and hit the trails can't wait.
Old Mar 29, 2003 | 11:04 PM
charlest's Avatar
charlest
welding "9rear
Is there a difference between MiniSpool and Spool?
Is one or the other better for a 4x4 with 9" rear?
Old Mar 30, 2003 | 12:05 PM
steve83's Avatar
steve83
welding "9rear
Yes - a mini (spool or locker) only replaces the spider gears inside the diff carrier. A full (spool or locker) replaces the whole carrier and is MUCH stronger & dependable for any vehicle.
This thread has links to lots of info on differentials and one shows the installation of a mini-locker, which is very similar to a mini-spool.
Old Mar 31, 2003 | 01:32 PM
TallGuy_Az's Avatar
TallGuy_Az
welding "9rear
I ordered a mini from a web site a couple of weeks ago. It was only $22.50 for the spool and an extra $9.75 for the steel pin. Hopefully it is as easy to install as Kevin says, because like him, I have never repaired anything inside of a diff.
Old Mar 31, 2003 | 01:54 PM
ba 302's Avatar
ba 302
welding "9rear
sweet truck tucker I had the same truck but only had 32/11.5/15s but let me tell you that truck went everwhere, it also pulled out many of chev's with lifts and hp small blocks. awesome truck and awesome pics.(ordering a minispool from e-bay great deal)
