Idle problems
Old Jun 26, 2011 | 11:19 PM
Canadian King Ranch's Avatar
Canadian King Ranch
Idle problems
i have a 2005 f 250 Diesel King ranch with AFE intake and MBRP Turbo back exhaust. i have no other mods and the rest of the truck in stock. Motor has 137,000 Km (85,000 ish miles)
just bought truck and installed intake and exhaust for better fuel economy.
After installing the exaust the truck started to idle randomly. Truck idles up a few 100 rpm, quikly then back to normal, power on exceleration seams not right either.
Old Jun 27, 2011 | 07:24 AM
embry1123's Avatar
embry1123
You will likely hear this from more than just myself, but... the stock air filter system is the best one available. It breathes as much air as your motor will need in stock configuration and filters that air better than any after market filter can. As far as the idle fluctuation, IDK... do you have any exaust leaks? Perhaps the MAF sensor is dirty. If you used an oiled type air filter, there is a chance that some of the oil has passed the filter and adhered to the MAF sensor, thereby giving it the best possible situation for collection of dirt. Just a thought.
Old Jun 27, 2011 | 09:06 AM
gearloose1's Avatar
gearloose1
Reinstall factory air intake / filter and see if that cures problem.
Next probability - insufficient back pressure.
Then... sensors kludged up.. EGR valve.
Old Jun 27, 2011 | 07:57 PM
Canadian King Ranch
thanks guys, the problem started after i installed the exhaust and the truck ran great with just the intake. i will try putting the intake back to stock and see what happens but i never had this problem till after installing the exhaust.
i kept the cat in when i had the aftermarket exhaust installed due to stiff regulations with pollution, think that could have anything to do with it?
anything i can do to clean sensors?
Old Jun 27, 2011 | 08:06 PM
gearloose1's Avatar
gearloose1
Exhaust Back Pressure tube / sensor is a known troublespot.
Clean / verify it.
EGR valve is another.
Start with those 2.
Instructions in tech folder.
Old Jun 27, 2011 | 08:09 PM
Canadian King Ranch
hey thanks alot i will try and see what happens. Any major benifits to removing cat.
Old Jun 27, 2011 | 08:13 PM
gearloose1's Avatar
gearloose1
If the cat is plugged, yes.
The increase in flow from cat to no cat if not plugged is small, but there.
If you wait long enough, the ceramic substrate removes itself as it falls apart.
Then you get the cat rattling around in the "can" like I have.
Old Jun 27, 2011 | 08:44 PM
Canadian King Ranch
i read the post about the back presure senor failure and this sounds alot like the idle problems i have been having so im going to start there. im not an idiot with tools but im not a mechanic, im also new to this site. is there anything i can do myself or should i replace it.... is it expensive?
Old Jun 27, 2011 | 08:48 PM
gearloose1's Avatar
gearloose1
It is most likely just a plugged tube.
Clean it first.. then clean sensor.. see if that works.
Old Jun 27, 2011 | 08:56 PM
Canadian King Ranch
THANK ALOT i hope this is the problem. just bought truck a few months ago, my first diesel. just have to find out how to clean it
Old Jun 27, 2011 | 08:59 PM
gearloose1's Avatar
gearloose1
Can almost guarantee you got a plugged EGR valve too... follow cleaning instructions in tech folder.
Esp. italian tuneup at the end of cleaning to blow out carbon.
Old Jun 27, 2011 | 09:18 PM
m-chan68's Avatar
m-chan68
This may sound like a stupid question, but does your truck in fact have a MAF sensor? You state that you have a 2005 model year truck. Early 2005s were equipped with a MAF. Late build 2005s weren't. 2006 and 2007 model years saw the return of a MAF sensor. Go figure.
Where abouts in Ontario are you located, by the way?
Old Jun 27, 2011 | 10:04 PM
Canadian King Ranch
ya i have a MAF sensor. im in Guelph ontario, looking for good diesel mechanic too, know any?
Old Jun 27, 2011 | 10:08 PM
gearloose1's Avatar
gearloose1
There is a good one in Brampton, very close to where you are, his name is m-chan68
Old Jun 28, 2011 | 07:07 AM
brickie's Avatar
brickie
Check for codes,when my 350 eats an ICP sensor the first symptom is a funky idle next is low power on acceleration and then then the surge at constant throttle sets in.
