Stumbling start...
Old Jun 26, 2011 | 09:41 PM
05whitef250's Avatar
05whitef250
Stumbling start...
I have an 03 250 and 1 out of every 4 starts stumbles pretty bad to start. --When it starts these times it just acts like it doesnt want to fire off, once i let go of the key the truck sputters and shakes a little bit and then fires off fine, runs fine, no smoke, no codes.
--I have also noticed that if i let it sit up and get cold (12 hours or more) that it will turn over for about 7-10 seconds before it fires off. When it takes this long to start it never stumbles, it just starts up and runs like a top. (Side note when i say it gets cold i just mean cools off, its been around 100 here for a month or so, but i have the same problem when it was 20 degrees outside).
Does anybody think the EBP sensor could affect this, i have actually gotten 2 EGR low flow codes in the past month and my egr valve is clean. I read that the EBP caused some issues with the 03s and would give a falso no flow code, however all of the symptoms caused by the EBP that i have read about are running problems. I have no running problems, only starting problems.
Old Jun 26, 2011 | 10:03 PM
cheezit's Avatar
cheezit
look at icp , ipr also look at icp koeo.
could be biased icp sensor or sticking injectors.
Old Jun 26, 2011 | 10:06 PM
BLADE35's Avatar
BLADE35
Time to get a SGII start watching some stuff
how are fuel filters
oil changed
check fuel press
for egr flow codes
have you cleaned the EBP sensor and tube also IAT2 in the intake manafold plays into egr flow codes too pcm needs to see temp change when egr open clean map sensor to
