1978 - 1996 Big Bronco
weld or not to weld
Old Mar 27, 2003 | 09:27 PM
ba 302's Avatar
ba 302
weld or not to weld
has anyone ever welded the spiders on a 9" rearend? and is it reliable for everday use?
Old Mar 27, 2003 | 09:33 PM
McLeod's Avatar
McLeod
weld or not to weld
Not for on road use!
Old Mar 27, 2003 | 09:42 PM
ba 302's Avatar
ba 302
weld or not to weld
why would'nt it be for on the road uses i'm if you weld it good should'nt it be just as good as factory posi?
Old Mar 27, 2003 | 09:45 PM
BroncoRoadKill's Avatar
BroncoRoadKill
weld or not to weld
Have you been smoking something? No seriously.
If the ring gear and other assorted items inside the diff break, the cost of repairs could be more than if you just put a locker or a positraction in the first place.
Old Mar 27, 2003 | 09:51 PM
BroncoRoadKill
weld or not to weld
oh yea, the point of having spider gears is that so the diff works by allowing one wheel to spin faster than the other one.
By welding the spider gears up your bronco would have a very hard time trying to turn on the pavement. It might be ok for off road uses if kept there.
just my 2 cents.
Old Mar 27, 2003 | 09:52 PM
ba 302's Avatar
ba 302
weld or not to weld
have'nt smoked anything yet thanks but I do think that if you weld it properly that should be just as good as a factory.
Old Mar 27, 2003 | 10:10 PM
McLeod's Avatar
McLeod
weld or not to weld
Go for it!
Old Mar 27, 2003 | 10:23 PM
ba 302's Avatar
ba 302
weld or not to weld
thats what I like to here I was beginning to think I was talking to a bunch of chev owners. why not if it breaks it breaks right. (***** to the walls)
Old Mar 27, 2003 | 10:34 PM
pashtrd's Avatar
pashtrd
weld or not to weld
is it reliable? sure till you snap an axle, then be glad it is a ford and not a chevy, you wont have to chase down your tire/axle.why not just do it right the first time? and put a posi in it. wouldnt you rather drive your truck than work on it?
Old Mar 27, 2003 | 10:47 PM
ba 302's Avatar
ba 302
weld or not to weld
thats 50/50 for me half the fun is driveing it and the other half is fixing it after a drove it. lol
Old Mar 27, 2003 | 10:52 PM
pashtrd's Avatar
pashtrd
weld or not to weld
yeah i suppose you are right. it just gets really expensive when you have to have your rearend set up 3 times, cause you went the cheap route the first time.
trust me i know
matt
Old Mar 27, 2003 | 11:02 PM
mrwizard's Avatar
mrwizard
weld or not to weld
Welding the spider gears will NOT make it like factory anything. Without having the spider gears able to turn, you will be able to drive in an absolutely straight line with no problems. As soon as you try to turn, even a little bit, you will start hopping the rear <a href="http://service.bfast.com/bfast/click?bfmid=37919709&siteid=39251846">tires </a>around the corner. I know what I'm talking about. I exploded the spider gears in the rear of my Mustang many years ago, essentially welding everything in place. Straight, fine... corners, NOT fine.
Even true locking differentials (Detroit Locker, etc...) will allow the outside wheel to spin faster around a corner and not have this problem. If this was for strictly off-road use, you'd probably be OK. On-road, you'd be sorry you did it.
And don't EVER call me a chevy owner.
Old Mar 27, 2003 | 11:31 PM
steve83's Avatar
steve83
weld or not to weld
You can easily spot the Chevy-owners by their use of the GM term "positraction" for a limited slip diff. Ford calls L/S "Traction Lock".
Old Mar 27, 2003 | 11:40 PM
BroncoRoadKill
weld or not to weld
Hey, I am not a chibby owner
I must have not been whatching what I typed. I gotta be more carefull.
Peace man
Old Mar 28, 2003 | 09:30 PM
McLeod's Avatar
McLeod
weld or not to weld
I think you need to lose the "K" in "LOCK".
Just being a hair splitter.
