need help identifying a part
Old Jun 26, 2011 | 06:05 PM
cory5517's Avatar
cory5517
Ok I have a 2001 Ford f250 4x4 7.3. Started out my a/c would stop blowing out of my ventsand blow thru defroster when I put truck in 4 wheel drive. Now I have no a/c unless I mess with a round silver part with a ARM, located under glove box next to heater core. What's the name of this part or what's the part number. Any help would ne greatly appreciative.
Old Jun 26, 2011 | 06:22 PM
MX_Fyrcaptain's Avatar
MX_Fyrcaptain
It may be part of your ESOF system. Not positive, but here's a bump for ya.
Old Jun 26, 2011 | 06:29 PM
cory5517's Avatar
cory5517
That's more help than I got from my local Ford dealer, they wouldn't talk to me unless I paid for a diagnostic. Thanks bud ill keep researching
Old Jun 26, 2011 | 06:51 PM
DND58's Avatar
DND58
Not sure on the silver part, but there is a blend door that directs flow. Can you get anything heat or AC to go anywhere but defrost? When these trucks have a vacuum leak, they default to defrost. Good luck.
crazymut's Avatar
crazymut
If I remember corectly that is usually a vacuum leak at your 4x4 hub actuator.
Old Jun 26, 2011 | 06:53 PM
MX_Fyrcaptain
X2 on Terry's reply
Old Jun 26, 2011 | 06:54 PM
tdpower's Avatar
tdpower
Does it have a vacuum line coming off the bottom. I just took a look at mine. That might be something associated with actuating the blend door but not sure. Maybe post a pic and someone can help identify it. If you have a vacuum leak it will default to defrost. You might try blocking off the vacuum lines going to the hubs one at a time.
Old Jun 26, 2011 | 07:02 PM
cory5517's Avatar
cory5517
When I manually press the ARM up on this round silver part my a/c works
Old Jun 26, 2011 | 07:10 PM
crazymut's Avatar
crazymut
Check that your vac lines are attached at your hubs.
Old Jun 26, 2011 | 07:16 PM
cory5517's Avatar
cory5517
Mechanic buddy of mine traced the leak to the round silver part behind glove box
Old Jun 26, 2011 | 07:25 PM
cory5517's Avatar
cory5517
So far its been a nightmare
Old Jun 26, 2011 | 07:38 PM
crazymut's Avatar
crazymut
By the way, welcome to FTE. What area are you from?
Old Jun 26, 2011 | 07:45 PM
cory5517's Avatar
cory5517
Thank you I'm from marble falls Texas
Old Jun 27, 2011 | 06:56 PM
cory5517's Avatar
cory5517
Man vacuum leaks are a nightmare, once again Ford would not talk to me unless I pay for diagnostic
Old Jun 27, 2011 | 07:03 PM
cory5517's Avatar
cory5517
aanybody know of a good website with pics on Ford parts?
