sealing front and rear windows
Just had my front and rear windows put in my 52 cab last weekend.
I know for sure that there was no sealant used before/during/after the
installation of either window..... should there be and how would I
do it? Where would it go? What should be used and how?
If I don't need it, thats ok also.
Thanks
Thanks
on
Thanks
Thanks
I put mine in without any sealant, but it never rains here, and if it did, I wouldn't be out driving in it (no wipers at the moment). I don't get any leakage when washing it with a garden hose, but if you shot a high-pressure spray on it, I bet it would weep. Nothing like the vent tho.
The sealant to use is butyl rubber. Do not under any circumstances use a silicone-based sealant, they will cause rust. Butyl remains pliable, and is available at paint/body shop supply houses in cartridges like caulk. If they have a nozzle made specifically to lift the rubber, sort of a flat shoe, they are well worth getting.
