OLD DECODES
#871
Bill, the owner used to be partners with Harold Looney, who owned several Ford Parts Obsolete stores, the last one in Stanton.
Looney (who wasn't crazy!), purchased all the used and NOS parts (excepting Shelby/Mustang), when Valley Ford Obsolete in North Hollywood sold out.
#872
I'm looking at buying a 1979 Ford dump truck, all I have is VIN F82BVDC5899, door plate is missing. Present owner thinks carb needs adjusting or rebuilt, so I'm trying to figure out what engine and if possible what the GVW might have been.
#873
B = 300 1V I-6 or 370 4V V8.
V = Kentucky Truck Assembly Plant.
DC5899 = 1979.
Warranty Plate riveted to the left door face below the latch // Certification Label glued to the B pillar (door post) below the striker plate.
Both have the GVWR listed.
#874
Hello
Could you help me out with the part# for a 1979 F700 fuel tank (gasoline) sending unit.
Its a round 75 gallon tank. If any other info is needed regarding the tank - please let me know.
And of course IF you can find one that is availiable.
Thanks so much.
John (Oldmics@Yahoo.com)
Thanks so much.
#875
And of course IF you can find one that is available.
Thanks so much.
Here's an example w/a 50, 75 or 100 gallon round tank: D4HF-9275-AA
#876
Bill
Thanks for the reply
There does not appear to be any info on the top of the sending unit. Perhaps the unit has to be removed and the info is on the bottom side in the tank?
Would the information on the metal tag riveted onto the tank be of any assitance to you?
Thanks,John
Thanks,John
#877
If it's the ID number for the tank on that metal tag, that'll be a big help.
#881
on
Little help needed...
Hey Bill,
Wondering if you might have any info for me on this part;
https://www.ford-trucks.com/forums/1...l#post18045235
Thanks for all you do,
David
David
#883
B = 300 1V I-6.
M60968 = 1972.
132" Wheelbase.
F500 (gas); 15,000 lbs. GVWR
4 8: 4 = Black Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
42 = Rockwell model D100 Single Speed Rear Axle / 6.20-1 / 13,000 lbs. Rear Axle Capacity.
15,000 lbs. Gross Vehicle Weight Rating.
126 net HP @ 3,400 RPM
462152:
46 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
2152 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order.
#884
wondering
hi mate been reading through your posts was wondering if you would have any info on my truck it in australia so maybe not thanks for any help these are the only numbers i have
cheers Stuart
cheers Stuart
