throttle body and tps
i think when i took the tps off i turned the prongs that catch on the throttle shaft
will this make a difference when i put it back together
once i had it running again and took it for a drive to relearn the computer i noticed the throttle responce is way better and smoother
the only thing is my rpm seems to stay high when i shift and when i come to stop it takes a bit for the idle to come back to 700
when i brought it home and pulled the codes with engine not running i got a system pass and with the engine running i got 172 system to lean and i did the test again then i got a system pass
my tps is good as i checked that when i had it apart i think i need an o2 sensor
could i have done something wrong to the tps when i was cleaning it
