Tach problems??
Lately the tach on my 93 F250 has been acting up.
Today I statrted it up and it read about 200 rpm,
the engine sounded good but it was shaking the truck.
About a mile down the road the tach started reading correctly again. Before that a couple of times while going down the road the tach started to slowly fall too about 200 rpm and then pop right back were it should be.
Also I have been having trouble with the oil gauge, sometimes it reads correctly and other times it barely reads. The engine sounds good when its reading low. I replaced the oil pressure sensor and it started reading correctly, but about three weeks later it started doing it again. I have hooked up a mechanical gauge and the oil pressure is good.
Any ideas out there??
Thanks,
Gr8ride
