Sponsored by: Real Truck
HELP= White Smoke HEAVY
Old Jun 24, 2011 | 10:51 AM
grizzweideman's Avatar
grizzweideman
My 1999 Super Duty Diesel started to have heavy FOG like exhasts after its last Oil change. I just rebuilt the Tranny a few months ago, and had to replace the #8 injector as well. Mechanic also recommends that we change out the Injector Control Module because #8 injector is still not reading correctly... but that has to wait thats about $1000!
Back to the smoke.... with the oil change we ran some Marvel Mystery Oil in with it to help clear out all the gook. We also rand some Diesel 911 in a tank of fuel and then the smoking started. The smoke is white and smells of exhaust, however if you are not going down the road it is so thick that you can't see the car next to you... (and you get a lot of people yelling at you).
Water is good... we changed the oil again this time without any marvel. Tranny fluid is good. Fuses area all good. We are at a loss... ANY SUGGESTIONS?
Another issue is after fixing a tranny leak 4 days ago my truck now randomly will not start in park but will start in neutral... other times it starts in Park no problem... any ideas here?
THANK YOU!
Old Jun 24, 2011 | 01:09 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Where did the injector come from? Sounds like something is wrong with that injector and is dumping lots of fuel into the cylinder.
Old Jun 24, 2011 | 02:10 PM
grizzweideman
The injector came brand new from Ford... and the new injector had been in there for over 3 months before this problem started.
Do you think it could be the control mod making it do this?
Old Jun 24, 2011 | 02:46 PM
miller_feed
What codes are you getting?
Old Jun 25, 2011 | 12:18 PM
flyer7.3's Avatar
flyer7.3
I blew a turbo once on a jap diesel, the symptems you describe are what I got before it blew.
Baz.
karter81
Feb 26, 2016 02:23 PM
Aakin
Feb 12, 2014 06:41 AM
linus72
Apr 16, 2012 07:40 AM
86fordf250
18
Nov 22, 2010 12:07 PM
Whitelightningboss94
Nov 14, 2004 12:48 AM
