I recently purchased a 1980 F-250 in fantastic condition but it only had the plane jane AM radio in it. I picked up a similar radio at the junkyard out of an 84, AM/FM with the long ***** like mine has and the wiring intact. I thought it would be just a matter of taking one out and throwing the other one in, except the am radio in my truck only has 4 wires coming out of it. 2 black ones which go to the speaker in the dash. A black one and a blue with a red stripe which plug into a yellow one and blue/red. I'm pretty sure this is all original, what would i have to do to connect my radio. Any help would be much appreciated!
If you got the stereo radio, you will need the speaker harness and the rubber conduit for the doors. You will also need some speakers.
If you got the AM/FM mono radio, you wont need the door speaker wiring.
No matter what radio you got, you will need to do something with the connectors. This is because the 1984 radio has different connectors to the 1980-1981. They changed the connectors in 1982, so it's not simple plug it in and play. You will have to modify the wiring slightly to get it to work with your trucks wiring.
its the AM/FM stereo. You're saying this wont work with the single speaker under the dash? thats unfortunate, i just want some FM radio. would you happen to know what the wires on the '84 radio are for? one harness has white/green, orange, black, pink/green and pink/blue. the other harness has orange, blue/red, and yellow/black.
Thats perfect! The second pic shows exactly what I need, THANKS! My setup is very similar. I'm assuming that the wires coming from the back right side of the radio are for speakers? would there be any way to connect these to my dash speaker or will i have to put in door speakers?
alright, this might be more of a project than i had anticipated lol. Thanks for the great info, i like the look of that red backlight. Hope to get some pics up soon
The reason for not using one speaker only has to do with the amplifier expecting at least two 8-ohm (or more) speakers.
I have no idea of the power capabilities of these old stereos and I'd be afraid of burning something out.
What you might be able to do, though, is hook up one speaker to the left (or right) input wires, then use the balance control to "shut off" the unattached speaker.
No guarantee for how long that would work, though.
The output IC's used when I repaired my radio my AM/FM radio were rated at 10 watts per chan. They were original part #AE920-8 and cross to NTE #1288. Most of these older radios can be repaired by replacing the capacitors and/or the audio output IC's.
I always cut the power to the radio when hooking up speakers, especially when doing it with an older radio that has hard to get parts.
Ignore any orange wire coming from the radio, that was sometimes used when the radio was installed in cars with power antennas.
All the pink & green stuff is for the speakers.
Not exactly. There is a Orange/Light Green hash wire for the Left Front Speaker channel, and White/Light Green Hash for the Right Front Speaker Channel. The Pink/Light Green is Left Rear, and Pink/Light Blue is Right Rear. The rear channels are looped to the front speakers on the pickups.
The Orange solid wire is for the power antenna, not used.
Originally Posted by 2002_F250
Would there be any way to connect these to my dash speaker or will i have to put in door speakers?
You could do this, but I'd advise against it.
There is something called ohm impedence mismatch, and this could destroy the dash speaker, or the amp components in the radio. In this case, you would have to hook all the speaker channels up to a single speaker so the radio amp won't take the hit (so to speak). This is why the rear channels loop to the front when they are not used so the amp wont be damaged. The pickup stereo speakers are designed to take the extra load of the front and rear channels combined. This is fine running two or four speakers. However it could overload the single speaker in the dash having at least twice the normal output going to it.
Here is a web page that will help to explain, or to confuse depending on your point of view.
