I'm replacing my door handle and window cranks. Where can I find large plastic washer that goes behind the handles to protect door panels? I can't seem to find new ones anywhere.
Thanks!
Saw a couple in the Mac's catalog pg 95. Not sure if that's what you're looking for.
Web site is Macsautoparts.com "nylon plate" 1967 p/n C5AZ-6223370-A or 1968-72 p/n. C8AZ-6223370-A
Hope that helps.
Hope that helps.
1963/67 Econolines use the same window crank handles (C1TZ-8123342-A) as 1961/66 F100/1100's.
But these plates are not listed for 1961/66 F Series trucks.
C5AZ-6223370-A .. Front Door Window Crank & Inside Door Handle Plate (no dimensions listed in the car/truck parts catalogs).
Applications: 1967 F100/750 / Myriad 1965/67 Passenger Cars.
C8AZ-6223370-A .. Front Door Window Crank & Inside Door Handle Plate / 1 9/16" O.D. x 3/4" I.D.
Applications: 1968/72 F100/750-window crank only / Myriad 1968/70 Passenger Cars.
NumberDummy how can I contact you. I am new here on this forum. My daughter has a 2002 Ford Escape Her driveshaft is in perfect condition but I accidentally tore the boot up at the front of the driveshaft, I seen on a old post that you know of a part # that will work, they do not sell this boot, not even aftermarket, Please help Jerry, e.mail jtkkwag1@centurytel.net
I have no Ford parts catalogs after 2001.
Contact FTE sponsor PARTSGUYED.COM (Horizon Ford in Seattle WA) for assistance.
i dont remember there being washers behind the cranks.... i just recently replaced my cranks and the door panel, and they didnt come with any washers (most parts come with everything already) but, i would look for a HotRod shop around your area. thats were i went and found that slider that keeps the rod connected to the door lock inside the door. or a junkyard.
