timing help
Old Jun 23, 2011 | 08:42 AM
88rustyred's Avatar
88rustyred
timing help
i have a 88 f150. my haynes manual shows where no.1 plug is on dist., but on the engine it looks like its off by one terminal.[like the dist turned when it was installed].i tried to stactic time it.every time no.1 piston comes up the timing marks are off by [maybe] about 90degrees. have plugs out doing compression test. and can see piston when it reaches tdc. this old thing is packing 180psi[WOW] i was expecting 140 to 150.
Old Jun 23, 2011 | 08:57 AM
JimsRebel's Avatar
JimsRebel
look for a small 1 stamped on top the the dist cap
Old Jun 23, 2011 | 10:02 AM
88rustyred's Avatar
88rustyred
its there. one terminal over [clockwise direction] according to what the book says.
Old Jun 23, 2011 | 10:14 AM
Harte3's Avatar
Harte3
The #1 on the distributor cap is irrelevant. Any terminal in the correct position for #1 will do.
Old Jun 23, 2011 | 09:50 PM
javi2001's Avatar
javi2001
The distributor was installed 15° advanced from the proper possition. Tha´s why the mechanic had to move all wires one possition. Just remove the distributor and reset it while engine is at 10° BFTC
