1978 - 1996 Big Bronco
Rear End Question??
Old Mar 27, 2003 | 01:15 PM
Turnerscasa's Avatar
Turnerscasa
Rear End Question??
I need to be completely sure what rear end is under my horse. I have this feeling after all my work I will not be happy without a detriot locker in the rear and a track loc in the front. I do know that I have a reverse cut Dana 44 in front. I think I have 3.55 posi out back with 32 spline in a 9 inch rear end.
Any help is good help thanks tons !!
My horse
1989 Bronco
<a href="http://www.motorhaven.com/">302 </a>5.0
AOD
Superlift 6inch
Procomp Xterains 35
15x 10 street lockers Rock Crawler
Old Mar 27, 2003 | 01:44 PM
bronco351's Avatar
bronco351
Rear End Question??
I'm a little confused with your question. I think your asking what kind of axle you have under your Bronco. Then you state you have a 9" rear end. So what exactly is the question. Could you please explain. Thank You!!!
Old Mar 27, 2003 | 01:45 PM
bronco351's Avatar
bronco351
Rear End Question??
Also could you tell us year and all that other great info. Thanks alot!!
Old Mar 27, 2003 | 01:56 PM
Turnerscasa
Rear End Question??
I dont know what axle I have, or rear end, or gears. That is what I'm asking the group for help with, thanks!
My truck is
1989 Bronco
<a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">302 </a></a>5.0
AOD
Superlift 6inch
Procomp Xterains 35
Old Mar 27, 2003 | 02:15 PM
bronco351's Avatar
bronco351
Rear End Question??
Oh, you have a 8.8" rear end with 3.55 gears. your front end is a dana44 with 3.54 gears. For me to tell you if you have open or Trak-Lok diffs, I need the axle code which is on the door <a href="http://www.motorhaven.com/">sticker</a> of your Bronco!!
Old Mar 27, 2003 | 02:19 PM
Turnerscasa
Rear End Question??
I'll post the code tomarrow. On the <a href="http://www.motorhaven.com/">sticker</a> it just says axel code?
Old Mar 27, 2003 | 02:29 PM
bronco351's Avatar
bronco351
Rear End Question??
Yeah there will be a little box that says "axle code " and under the word will be the code!!
Old Mar 27, 2003 | 11:14 PM
steve83's Avatar
steve83
Rear End Question??
It's 2 digits: if the first digit is "1", you have an open diff carrier; if it's "H", you have a limited slip. For 3.55 ratio, the second digit will be "9". "H8" is 3.08 L/S.
