Hard start/Rough idle/Rough running
Old Jul 30, 2011 | 01:56 PM
427 fordman's Avatar
427 fordman
You need a scan tool like AE, I myself have never ran one either.
Old Jul 30, 2011 | 02:59 PM
BieselDiesel's Avatar
BieselDiesel
How can I test the IDM?
Old Jul 30, 2011 | 03:07 PM
427 fordman
I've never read a way to test it on here, if by chance you'd have a buddy with any year 7.3 powerstroke, 94.5-03, you could borrow theirs for a quick swap.
Old Jul 30, 2011 | 03:14 PM
Action4478's Avatar
Action4478
Did you record the ohm readings for the injectors on the side thats not running. If not , test them again & post the numbers ...
Old Jul 30, 2011 | 07:08 PM
BieselDiesel
Ok. I took the IDM off. I noticed that it sounds like it's got water inside. I don't think it's suppose to sound that away.
Old Jul 30, 2011 | 07:12 PM
Action4478's Avatar
Action4478
Sounds like you found the problem ....
427 fordman
That happens with these trucks some. Not a big suprise. Sounds like you're gonna need a new one. Get one from a 99-03 7.3 if you can, they are an upgrade to ours. 120V compared to 100. I bought a remanufactured off of ebay for a spare to have for 120 bucks.
Old Jul 30, 2011 | 07:31 PM
BieselDiesel
I see an Ebay where there are several differnt part numbers. Does that matter? Or just as long as I get one for a 99-2003 regardless of the part number?
Old Jul 30, 2011 | 07:33 PM
427 fordman
As long as its for a 7.3 powerstroke, you're good.
Old Jul 30, 2011 | 08:04 PM
BieselDiesel
Here is the part that is on it's way!!
2001 2002 FORD 7.3L DIESEL MODULE XC3F AD IDM 120
Old Jul 30, 2011 | 08:12 PM
Action4478's Avatar
Action4478
Old Aug 7, 2011 | 03:29 PM
BieselDiesel
Well new IDM installed on viola it's back up and running.
Thanks guys for all your help. It is greatly appreciated.
Old Aug 7, 2011 | 04:26 PM
  #28
Action4478's Avatar
Action4478
Good to hear .
Old Jun 11, 2019 | 07:51 PM
  #29
MichaelAnthony's Avatar
MichaelAnthony
Same issues
Well I have had the same issues off and on for a while now. Replaced the ICP, IPR, Valve Cover harnesses, and still have the same intermittent issues. I did notice when it is dry out she runs better than ever, when it rains it's tough to start or run for that matter. I ordered a green OBDLinks II code reader but it doesn't read any codes and yes it is connected. Ordered another BAFX code reader will be in Thursday. The 13th of June will try that one out for codes. Will look for any IDM? Most on Ebay say they need the VIN number to properly load the software. Let me know thanks.
Old Jun 11, 2019 | 09:59 PM
  #30
farmert's Avatar
farmert
An IDM from any year 7.3 will work on our trucks. The one the NBS takes is a little higher voltage out put.
