Never used guideplates
Old Jun 20, 2011 | 10:27 PM
SmealDeal's Avatar
SmealDeal
I'm restoring my dads old truck top to bottom... I've never had heads ported before and assebled them myself. I followed most of the performance shops advice on head parts as they did the porting and just sent me all the parts along with the fresh heads, but the guidplates seem shaky to me on the studs. Do they center themselves as they are tightened down? I don't want to geuss after all this trouble.
Old Jun 21, 2011 | 08:13 AM
f100jim's Avatar
f100jim
Well, you didn't give us much information, but it SOUNDS like you are saying that the guide plates are a loose fit on the rocker studs. So, I am guessing that your heads were converted to screw-in rocker studs. The head shop supplied the parts, so hopefully they gave you the correct parts. The rocker studs, if they are designed for use with guide plates, should have a shoulder under the hex that fits the holes in the guide plates. It is called a "guideplate locator shank". Check your studs and see if there is a shoulder under the hex that fits the guide plate holes. If not, they may have given you the wrong rocker studs.
Old Jun 21, 2011 | 12:20 PM
Franklin2's Avatar
Franklin2
Make sure they machined a flat area for the guide plates and studs to sit. The factory heads need to be machined and modified in this area for guide plates.
michbol
Nov 14, 2011 01:25 PM
mmuenchow
Jul 10, 2005 09:28 PM
EgoMan
22
Jun 23, 2004 07:14 PM
fred_darrel
Feb 7, 2003 06:14 PM
erikl85
27
Dec 2, 2002 04:19 PM
