Android Torque App and ELM 327
Old Jun 20, 2011 | 02:59 PM
doczenith1's Avatar
doczenith1
Need some help here. I just got my ELM 327 in the mail and I'm not getting values for everything with the torque app. I get volts, load and fuel % but that's about it. Also, it recommended that I turn off the fast communication. I'm running a Droid X. In the attached image the top red and middle green stay lit while the others blink if I remember correctly.
Thanks,
Al
Old Jun 20, 2011 | 05:16 PM
Tomahawk's Avatar
Tomahawk
Al,
Go to the screen where you want to add gauges, press the Droid menu key, then "add display", then select what type of display you want, analog, digital, etc. All of the active sensors will be highlighted in green, then select the sensor you want. The truck should be KOER when you do this.
-Gavin
Old Jun 20, 2011 | 05:49 PM
doczenith1's Avatar
doczenith1
Didn't have very many options that contained data. Coolant temp, Fuel level, Engine load and Volts were the only non-gps sensors with data. Also, it seems like the fast communication is working now. I'm experiencing the same issue with the coolant temp that you mentioned in another thread.
Old Jun 20, 2011 | 08:12 PM
Tomahawk's Avatar
Tomahawk
No oil temp, trans. temp or RPM?
Tugly
29
Jan 25, 2021 06:28 PM
Whitey Ford
2009 - 2014 F150
Mar 20, 2016 12:19 PM
jed1894
Nov 20, 2015 01:43 PM
joegeds
Aug 10, 2015 11:39 AM
Ford_Six
Garage & Workshop
Apr 1, 2015 12:29 AM
