The headlights on my stock 51 just went out then came back on. I heard a click that came from the switch when they came back on. It still has the 6 volt system. BAD switch maybe ?
Looking at the 51 schematic there is a black with orange tracer wire coming off your light switch that leeds to your breaker then down to dimmer switch if you need a point to start tracing. I agree probable cause in dimmer switch, if it happens again you can hit the dimmer switch to see if its on the high or low switch circuit or both. do you have a schmatic?
Actually, my dimmer failed to where it would do just what you describe, Fred, but there wasn't a short, it just made a poor connection. If it happens again, try stomping on the dimmer.
