Sponsored by: Kumho
Bad ball joint??
Old Mar 27, 2003 | 07:22 AM
tomo805's Avatar
tomo805
Bad ball joint??
I've been hearing a loud squeaking noise while driving. At first I thought it might be a shock, but last night while just sitting in the driveway I heard it while turning the steering wheel. The noise is coming from the upper ball joint. That is the only place I can feel it by touch. There are no grease fittings to lube it with. Can you have a servicable ball joint installed? The joint doesn't seem bad, just dry.
Old Mar 29, 2003 | 07:35 PM
RRMike's Avatar
RRMike
Bad ball joint??
I'm not aware of a greasable ball joint. Call your local parts store. They will tell you.
