Anyone here using the coolingmist basic system? Seems to be a steal at $299.00. I'm just looking for a basic unit to help keep exh. temps. down and add a little power while towing a 5th. wheel. Truck is basically stock, BTM, 10k mod. 6.0 trans cooler. Will this basic unit do the trick for me??? Thanks in advance for your comments and help.
The factory relay on my AEM water injection system stuck on, pumped all the water in my engine and hydrolocked it bending a rod. I am no longer in favor of the idea! My new truck is nice though.
If you are going to use it for towing I would suggest a large 7 gallon tank. You will go through water pretty fast if you are towing heavy.
I use the Snow Performance Stage 3 and am very happy with it. Personally I would spend the money on a digital controller so you know when it is injecting.
I use the water on mine since the van does not have a intercooler works good but I agree you need a big water tank (mine 20 gallon) plus I run a filter, I had a nozzle pulg from garbage water.
