Starter Problems
Old Mar 28, 2003 | 02:53 PM
billt_57's Avatar
billt_57
Starter Problems
Hello all, this is my first post to FTE. I just recently found this site and have found it to be very informative. I recently purchased a 1976 F350 with a <a href="http://www.motorhaven.com/"><a href="http://www.motorhaven.com/">460 </a></a>motor. The truck runs great, until I try to restart it after warming it up to operating temperature. If I try to restart, the starter motor barely turns over. After letting it cool down for 10 minutes or so it starts easily. Does this sound like it's time for a new starter, or is it a characteristic of 460s?
Thanks in advance.
Bill
Old Mar 28, 2003 | 05:50 PM
jor's Avatar
jor
Starter Problems
My <a href="http://www.motorhaven.com/">352 </a>with headers had the same problem. A new starter fixed it.
jor
Old Mar 28, 2003 | 07:35 PM
Mike W's Avatar
Mike W
Starter Problems
Hi, you have a big engine. A battery that works fine on a <a href="http://www.motorhaven.com/">302 </a>won't cut it on my 390. I had to go to a real truck battery.
Old Mar 28, 2003 | 08:49 PM
RRMike's Avatar
RRMike
Starter Problems
I don't know if they make a heat shield for those but I know it's a common problem on chevy's and they have several aftermarket heat shields to protect the starter from the heat of headers.
A new starter should cure the problem but may develop the same thing over time.
Does the truck have headers? If so you can insulate them and that will help also.
Vapor lock is another common problem. Try backing your timing off a little and see if it still does it.
Old Mar 28, 2003 | 09:06 PM
macguyver's Avatar
macguyver
Starter Problems
One way to tell if it's starting hard because of the timing is when it's acting up, disconnect the coil wire from the distributor and ground it to the intake. If it turns over normally, back off the timing a little.
Hope this helps.
Greg
Old Mar 31, 2003 | 10:13 AM
billt_57's Avatar
billt_57
Starter Problems
Thank you for your replies. The truck has the stock exhaust, and I have not yet checked the timing.The battery appears to be fairly old, so now I have a few things to look into.
Cheers,
Bill
Old Mar 31, 2003 | 12:13 PM
460f250's Avatar
460f250
Starter Problems
I bake about a starter every 2 years on my 429, with no headers. I haven't gotten smart enought yet to install a heat sheild. It could be the same on the 460 although I haven't had that trouble on mine yet.
Old Mar 31, 2003 | 01:50 PM
Chas1234's Avatar
Chas1234
Starter Problems
One other thing you may want to replace is the battery cables and the lead from the solonoid to the starter itself ..I would try that before replacing the starter as it is cheeper . also try checking the water level in the battery and add as needed
(distilled water)
Jon
