Receciver
Old Jun 17, 2011 | 12:55 PM
Bat-Masterson's Avatar
Bat-Masterson
Receciver
Did not even think of this when I just picked up my 2010 F-250
because my other 250 I had for many years had a beefier receiver and I hauled 7000 lbs plus with it on a daily bases hauling bread and cookies.
Now my new to me 2010 is rated for 600 lbs and 6000 lbs without having a WD system on.
What comes to my point, even though I am out of hauling stuff for a living on a daily bases, I do have a 7000lb rated trailer and when I do use it, it will be maxed out a few time a year. and really don't want to mess with the WD system, will my 6000 lb reciever do the trick or should I spend the $200 and get a beefier receiver put on. like a
1000 TW 10000 GTW/
1200 WDTW 12000 WDGTW
I see they make bolt on with no drilling
Old Jun 17, 2011 | 03:36 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I would suggest that you use the WD setup for either of those hitches....for safety sakes if no other! You are pushing or exceeding the limit and you will have MUCH more stability in either case!
Old Jun 17, 2011 | 05:46 PM
Bat-Masterson
You are absolutely right keep the receiver I have on, and just get a WD never used one But I am sure once I use it a couple times sure it will get easy,
anyways next trip with the trailer is moving the kids car and some furniture to Grad school in Nashville and will be going though the mountains.
Old Jun 17, 2011 | 08:12 PM
lakedweller's Avatar
lakedweller
An ounce of prevention is worth a pound of cure. I myself would up the hitch.....
Old Jun 17, 2011 | 08:35 PM
Bat-Masterson
Wondering why Ford does not put the more heavier GW receiver on the trucks
for needing a Weight distributing to pull bigger loads, I just don't see many Weight distributing hitches out on the road.
Old Jun 18, 2011 | 09:46 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
It's hard to see between the truck and the trailer!!!! You NEVER see one on just the truck alone!
Old Jun 18, 2011 | 11:12 AM
TexasRebel's Avatar
TexasRebel
putting a point load of 1,000# 3+ feet behind the axle is not safe in a super duty no matter what the number on the receiver says.
I guess you could always stick some tractor weights up front to ballast it out, but then you're just carrying extra weight around everywhere.
Old Jun 18, 2011 | 06:07 PM
loganworks's Avatar
loganworks
Your existing receiver will handle the trucks max tow rating easily when properly equipped with a WD hitch. You will also be surprised at the difference in the ride when using the WD, no more feeling like you are being bounced down the road by the trailer. It will be some of the best money spent for towing.
Old Jun 19, 2011 | 01:32 PM
Super Steve's Avatar
Super Steve
I just noticed that the other day on my truck too.
The receiver says 600lb tounge weight and 6000lb trailer weight max.
I'm pretty sure I was way beyond that pulling a 28ft enclosed trailer loaded up.
I just though it was odd that Ford would put a receiver on there that wasn't able to match the trucks capabilities.
