Speedo read
Old Jun 16, 2011 | 02:43 PM
BoomerTexas70's's Avatar
BoomerTexas70's
Speedo read
Afternoon ya'll,
I just replaced my speedo gear on the cable end. With a 17 tooth, used the bronco graveyard calc. But my speedo still doesnt constantly work, it is intermitent. Whats the next step, where should I look for what kind of problem? Thanks ahead of time for the input.
Boomer
Old Jun 16, 2011 | 04:42 PM
HIO Silver's Avatar
HIO Silver
It is likely the cable or the speedometer assy in the dash.
Here's a test but it takes two people... remove your instrument panel and have your passenger observe if the drive cable ever stops spinning. If so, then it's the cable or the tranny... the latter is less likely.
If the cable behaves like it is supposed to, then I wou'd say that the speedo assembly inside the instrument panel is going kaput.
Old Jun 16, 2011 | 06:51 PM
Grendelx's Avatar
Grendelx
I had this issue once after removing my instrument cluster... I believe my problem was caused by the shaft not being completely locked into the speedometer.
