99 5.4 won't start
Key-on engine off pressure should be between 35 and 45 psi according to the WSM. KOER should be between 28 and 55. You have adequate pressure provided the pressure doesn't drop immediately upon cranking the engine. If your buddy is dead set on it being the regulator, tell him to replace it and call you back when it still doesn't start.
The '99 does have PATS. If it is preventing starting, it will indicate this by a fast-flashing THEFT light. Someone will have to make this observation.
Key-on engine off pressure should be between 35 and 45 psi according to the WSM. KOER should be between 28 and 55. You have adequate pressure provided the pressure doesn't drop immediately upon cranking the engine. If your buddy is dead set on it being the regulator, tell him to replace itand call you back when it still
doesn't start.
have to make this
observation.
doesn't start.
have to make this
observation.
He said the other night that the theft light above the speedo I think started flashin faster as u tried to crank it.
NorthCarolinaExpy
1997-2006 Expedition & Navigator
15
03-06-2015 10:08 AM
dwildey
1978 - 1996 Big Bronco
08-14-2011 12:49 AM
Jayme Duty
22
04-04-2010 05:12 AM
Humam1953
01-01-2007 10:13 PM
