I just changed the oil and filter on my 6.0 and the old filter was a Hastings it wasn't in the the cap like the motor craft filter is supposed to be , do you think it matters, and is the hastings filter better. I put the powerstroke oil in it,15-40.
Nice truck Jim , the other thing I was reading was the 14 qrt refill so I did it , seems good , I had a small drip on the bell , it seems to have gotten less wet, maybe wishful thinking ,
Filters..fuel or oil need to be either Motorcraft, Navistar (International) or Racor branded; all three are made by Racor. 14 qts seems low...mine takes 15 to get it up to the top end of the cross-hatches.
You can also use a Fram oil filter: CH9549...but you have to make sure it's got the felt ring on the bottom, the patent numbers on the top and the top cap is molded on the filter media (pleats)...and not a snap-on. Any filter that comes with a new oil filter housing cap...is the wrong filter.
