1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Strech your short bed?
Old 06-14-2011, 02:14 PM
jc8825's Avatar
jc8825
jc8825 is offline
Would you ever let a company cut and extend your frame to fit a longer bed?
Check this out:
www.longbedmytruck.com
Figures, it's a Dodge thing.
I cannot see how the expense of this would ever be recouped. Maybe if you kept the truck for 50 years as a collector item, but how many people realistically do that?
Old 06-14-2011, 03:38 PM
dkf's Avatar
dkf
dkf is offline
Basically its only for the Dodge (RAM now) Mega Cab because they only come in short bed. Funny thing is you look in their for sale section and most of them look like mall crawlers and the bed probably doesn't get used anyway.
Old 06-14-2011, 03:40 PM
jc8825's Avatar
jc8825
jc8825 is offline
You can't USE a Dodge truck...
Old 06-14-2011, 06:44 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I've seen this. It just seems like a bad idea..
Old 06-15-2011, 07:06 AM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
WARNING: I received a "Trojan" when I clicked on the website's "Contact Us" icon.
Details: Trojan.JS.Redirector.qd was found in C:\Documents and Settings\Andrew Saine\Local Settings\Temporary Internet Files\Content.IE5\I5G8O0Z3\contact[1].htm on 6/15/2011 8:03:30
Old 06-15-2011, 11:39 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Sounds like a personal problem :P
Old 06-15-2011, 12:30 PM
wizardsr's Avatar
wizardsr
wizardsr is offline
The mega cabs are really only good for mall crawling. They're not recommended for snow plowing due to frame and cab flex, and they have ridiculously low tow ratings. On my way through Wisconsin this spring, I saw a mega cab dually near Madison pulling a car trailer. The road wasn't exactly smooth, and the trailer was really handing it to that poor truck. The flex between the cab and bed was UNBELIEVABLE, I was surprised the bad wasn't hitting the cab, it was dang close! The driver was all over the cab. I almost felt bad for him. I can only imagine what stretching one of those things would do to an already weak truck.
Old 06-15-2011, 01:29 PM
jc8825's Avatar
jc8825
jc8825 is offline
I had no idea the Mega Cabs had low tow ratings. What are the ratings? Is it just because the cab is so large? I mean, with the short bed that they come with, they should still be slightly shorter or the same length as a crew cab long bed. What would cause the unusual frame flex?
Old 06-15-2011, 03:27 PM
SDElwood's Avatar
SDElwood
SDElwood is online now
It's a <del>Jeep</del> Dodge thing, you wouldn't understand.
Old 06-15-2011, 04:03 PM
Hybris's Avatar
Hybris
Hybris is offline
Answer to question #1.
All of these trucks are Ram 3500 4x4s.
The first two columns (Left to Right) are SLT trim trucks with the latter two columns being Larmine Longhorn Editions or "LLE" for short
{RegCab} {MegaCab} {CrewCab}{MegaCab}
{SLT} {SLT} {LLE} {LLE}
<table style="width: 504px; height: 100px;" class="content_body_ram_table" id="compareDataTable" cellpadding="0" cellspacing="0"><tbody id="Capacities/Weights_body"><tr id="tr_Capacities/Weights_6"><td class="content_body_ram_td_border_rb" id="td_2903_0">Payload Capacity - Standard
</td><td id="td_2903_1" class="content_body_ram_td_border_rb">4940 lbs.</td><td id="td_2903_2" class="content_body_ram_td_border_rb">2590 lbs.</td><td id="td_2903_3" class="content_body_ram_td_border_rb">4330 lbs.</td><td id="td_2903_4" class="content_body_ram_td_border_rb">2530 lbs.</td></tr><tr><td colspan="5">
</td></tr><tr id="tr_Capacities/Weights_7"><td class="content_body_ram_td_border_rb" id="td_2867_0">Towing Capacity - Maximum</td><td id="td_2867_1" class="content_body_ram_td_border_rb">22300 lbs.</td><td id="td_2867_2" class="content_body_ram_td_border_rb">18050 lbs.</td><td id="td_2867_3" class="content_body_ram_td_border_rb">19050 lbs.</td><td id="td_2867_4" class="content_body_ram_td_border_rb">17900 lbs.</td></tr><tr><td colspan="5">
</td></tr><tr id="tr_Capacities/Weights_8"><td class="content_body_ram_td_border_rb" id="td_2890_0">Towing Capacity - Standard</td><td id="td_2890_1" class="content_body_ram_td_border_rb">11600 lbs.</td><td id="td_2890_2" class="content_body_ram_td_border_rb">10950 lbs.</td><td id="td_2890_3" class="content_body_ram_td_border_rb">12900 lbs.</td><td id="td_2890_4" class="content_body_ram_td_border_rb">12900 lbs.</td></tr></tbody></table>
In the more basic trims Payload is cutback roughly in half for the MegaCab, the Max Tow capacity is cut by 4000 lbs or so, and standard towing is a more or less negligible 650 lbs.
Moving to the Higher trims and comparing between Crew Cab and Mega the capacity loss is more less the same considering both are 4 full door cab trucks.
Unless someone beats me to it I'll post a comparison between the Ford and Chevy Cab/Capacity loss ratios sometime later.
Old 06-15-2011, 04:11 PM
panama red's Avatar
panama red
panama red is offline
sounds like a bad idea
sumbuddyloanmea.10
50
05-29-2010 07:22 PM
FLYBOY07
Ford vs The Competition
31
04-25-2007 09:59 PM
150ford
394
03-12-2006 09:39 PM
150ford
202
08-08-2004 05:36 PM
godxofxemptiness
07-16-2004 05:30 PM
Quick Reply: Strech your short bed?
