302 WaterPump
Old Mar 26, 2003 | 04:45 PM
frozen bronco's Avatar
frozen bronco
302 WaterPump
Will a Ford Racing Maximum Flow Aluminum water pump (PNE6MS-08501C50-M) for a 1986-1993 Mustang fit a <a href="http://www.motorhaven.com/">302 </a>for a Bronco.
the description reads:
Premium reverse rotation serpentine belt aluminum water pump. Heavy duty shaft and bearing with stamped impeller. Provides good flow and pressure for engines that operate below 6000 RPM. Will fit 1979-1985 with minor modifications.
Thanks guys I know someone here can help me, you've never let me down in the past.
