Leaf Spring U-Bolt?
Old Jun 12, 2011 | 10:53 PM
rschwab's Avatar
rschwab
Question Leaf Spring U-Bolt?
I recently lowered my truck and I had to add 6 deg pinion angle shim. Now when I reassembled the threaded end of the u-bolt only ends up flush with the top of the nuts. Is this enough thread?
Could I used a crush nut or something?
I know you are not supposed to reuse them after they have been torqued, but I will be disassembling again at a future date and don't want to spend 50 bucks just to throw it away and do it again soon.
Old Jun 13, 2011 | 10:53 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I do like to have a least one thread exposed, but the U-bolts are usually grade 8 and see no problem reusing them. The nuts I would replace if self locking or Nylock nuts. Of course if your specs say do not reuse, thats your decision.
Old Jun 13, 2011 | 03:30 PM
HIO Silver's Avatar
HIO Silver
Use red threadlocker... Loctite 271.
Personally, I like to have the exposed threads equal the height of the nut threaded on it.
Old Jun 13, 2011 | 10:36 PM
crazed87bronco's Avatar
crazed87bronco
I agree with HIO silver I like the threads to be out the top some if you don't want to get new u bolts then use some loctite so they don't rattle off for now
Old Jun 14, 2011 | 10:49 PM
allwthrrider's Avatar
allwthrrider
I see your in Northern California, If your anywhere near Dixon ( Between Sacramento & Vacaville) there is a shop called Valley Spring he has raw stock all different length's and can bend you whatever you need & is reasonable priced
Old Jun 14, 2011 | 11:32 PM
rschwab's Avatar
rschwab
That's good to know. I am outside Vacaville off 505 Allendale exit.
Old Jun 14, 2011 | 11:37 PM
rschwab's Avatar
rschwab
Thanks for the answers guys.
Old Jun 15, 2011 | 08:57 AM
allwthrrider
FAA regulations require 1 full thread exposed, used to be 3, I'm about 5 miles from you
Old Jun 15, 2011 | 09:42 AM
rschwab's Avatar
rschwab
You must be an A&P.
My son is in the process of converting his military to civilian. He is an Apache mechanic/crew chief.
Thanks
DGMFORD
Mar 27, 2010 03:59 PM
joe chevy
Nov 20, 2009 05:02 PM
dmgiff
Jan 8, 2005 02:39 PM
iskybantilus
Nov 3, 2004 05:48 PM
