Fuel rail plug
Old Jun 11, 2011 | 03:35 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Fuel rail plug
Opposite corners on the head.... Need to remove the plugs. What tool should be used to remove these? Really don't want to strip them, just makes it harder to get out. Passenger and Drivers sides. My 8 mm socket and wrench won't work. Wants to strip them both.
Old Jun 11, 2011 | 06:52 AM
F350-6's Avatar
F350-6
It's a square plug so you can get the open end of a wrench on it. A small pair of vice grips will also help in breaking it loose so you can switch to the small wrench.
Old Jun 11, 2011 | 07:09 AM
bulla's Avatar
bulla
Yea I had to use vise grips when I installed my frx.
Old Jun 11, 2011 | 07:16 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
i used a tiny box wrench...open end wrench if you will.....
Old Jun 11, 2011 | 10:13 AM
izzybird's Avatar
izzybird
I've had good luck using a quality small adjustable wrench and lots of penetrating oil. A Harbor Freight special won't work, the jaws will spread and start rounding it out.
Old Jun 11, 2011 | 10:15 AM
cj45lc's Avatar
cj45lc
I used the "spline looking" socket from Craftsman on mine, I think it was the 5/16 one that fit. IDK if that's the right name for the sockets but that's what they look like & work great on square plugs. I also sprayed PB on the plugs for a couple days before trying to remove them.
Old Jun 11, 2011 | 10:20 AM
izzybird's Avatar
izzybird
Ahhh yes, good call. Those are some biting sons-a-b's, probably work real well.
Old Jun 11, 2011 | 10:28 AM
cj45lc's Avatar
cj45lc
Yessir they do, I was really worried about making a mess out of those plugs (I have that kind of luck) so those sockets were a part of my FRX expense & will be good to have around
Old Jun 11, 2011 | 11:41 AM
hhowell1990's Avatar
hhowell1990
If they're square you might want to try an 8-point socket if you can get one on it from that angle
Old Jun 11, 2011 | 12:02 PM
bluescrew's Avatar
bluescrew
i'd use a wrench.. looks like a 8mm or so... pb blaster too
Old Jun 11, 2011 | 04:38 PM
mueckster's Avatar
mueckster
IIRC, I used a 9/32" MAC combination wrench on mine.
Old Jun 11, 2011 | 04:48 PM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
They are out. PB Blaster and an 8mm wrench. Plus, a little bit more effort. When you work until 2:00am trying to get things done, mistakes happen. So, I picked up my tools and closed the garage door. Just about stripped the back plug. Have one more fuel line to install and hooking up the second pump left to do before testing.
Old Jun 11, 2011 | 04:53 PM
cj45lc's Avatar
cj45lc
Glad you got them
Old Jun 11, 2011 | 06:11 PM
milleroutdoors's Avatar
milleroutdoors
I use a 5/16 square plug socket. If I would have been thinking I would have sent it to you to use.
Old Jun 13, 2011 | 12:15 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Thanks Mark, I do have one more truck to work on. So, if you want, send it up. Not Ed's he's all OEM...
It was not the 8mm wrench, its a 7mm wrench. Finished the fuel system tonight. Will make some changes later on. 45 degree fittings for the front of the heads and straights for the rear. Will have to make some adjustments when the new turbo goes on, but its minor. Just about everything came off the top to do the work easier. Even the two eyelets for pulling the motor. I know someone who can make a pretty good eyelet dead center without the motor rolling....Rockrunner.
