Braking problem
Welcome to the site!
Did you replace all 4? And it did it stop better right after you changed them? Check that one wheel isn't heating up more than the others indicating stuck caliper..
Rear emergency brakes ok?
FYI usually when you change the front rotors the pedal shake will disappear completely. Rears not so much but will do it.
Could have bad bearings in front possibly!
wegotjs
12-31-2009 04:02 PM
