Sponsored by: Real Truck
Busted
Old Jun 10, 2011 | 10:59 AM
CornTruckDriver's Avatar
CornTruckDriver
Angry Busted
My plastic runningboard broke off when I stepped it the other day in the heat. I am heavy but far from the heavyest guy to ever climb in one of these trucks. Its an 04 and has the round boards. I found a website
Ford F-250 Running Board that at one time made the boards and the weight rating is incredible, however they dont make them for ford anymore. The board that broke was a replacement from Nov 09 and may be from another company. Then there is the issue of the new design for my new truck, I dont want this happening again. I have a bad hip and dont like the the chrome ones. Does anyone know the weight rating of the new boards. Any help would be appreciated
Old Jun 10, 2011 | 12:25 PM
lakedweller's Avatar
lakedweller
Mine are rated for 500 lbs and I love them. They are made of aircraft aluminum and boxed. The only problem I had was they were sent with only 2 brackets and they would flex slightly when I stepped on them, I am a little over 300 lbs. I emailed the seller and he had the manufacturer send more brackets, now no flex and they are great. Aircraft aluminum lasts forever. PM me and I will give you the info.
wizardsr's Avatar
wizardsr
How about replacing it with the same factory running board and having a fab shop add a bracket under the running board that goes back to the frame to reinforce the board. Wouldn't be too hard to do for someone with the know-how and a welder.
chefcollins1
May 12, 2014 01:23 AM
deeno360
Sep 18, 2013 10:04 AM
mrsmallard214
Jun 16, 2010 06:12 AM
jeffdoerr
27
Nov 22, 2009 06:09 PM
ranger pat
Feb 4, 2004 10:16 AM
