suspension question NOT 4x4
Old Jun 10, 2011 | 08:25 AM
FourXFords's Avatar
FourXFords
I Have a 2000 7.3PSD 2wd EX (since new) and am ready for real permanent improvements for the mushy springs I have now.
I'd like to only do it once.
Only towing done isa 24 foot boat on weekends and that's not an issue now.
Lately it's like driving a sponge (had to buy replacement tires on vacation and got screwed into sumitomo-supposed-to-be-E-rated-tires)
Tires wearing on the inside and choppy, I presumed it's springs that have lead to camber in. Shocks are only 1 yr old (10K miles) Monroe gas charged.
Wouldn't mind stiffer springs, but gotta keep wifey's ride kinda smooth too. Mostly city or highway roadtrips with the family. I know there is a 2wd EX PSD suspensuion guy out there.
Old Jun 11, 2011 | 09:05 AM
FourXFords's Avatar
FourXFords
Any suggestions for the 2wd EX
Just checking, can anybody see this?
Old Jun 11, 2011 | 09:47 AM
dsquared's Avatar
dsquared
Here's a bump for you!
I have 2001 XLT 2WD PSD. When I bought it used, it had Bilsteins. I changed them out about a year ago for the Monroes, also.
You may want to look into the RAS for the rear. It really helped firm up the ride, but it is not harsh.
I had Yokohama Geolandar HTs on it for ~ 50,000 miles; no complaints at all. Changed to Pirelli Scorpion AT earlier. Like you, mostly highway miles.... Tires are doing me fine. No snow problems here in SoCal.
Beyond that, not much help for you. Good luck!!
Old Jun 11, 2011 | 10:48 AM
chazman's Avatar
chazman
Tire ratings and tire pressures....
Old Jun 11, 2011 | 01:54 PM
aortizexcursion's Avatar
aortizexcursion
Just like the "V/B spring" mod for the 4WD Excursion, look into some springs from a Super Duty. I can't give you specific spring codes but I'm sure they're on the forum somewhere.
I'm not sure if 2WD Excursions were ever available with stock Anti-roll bars so you might want to look into that as well. A hellwig bar, a 30mm bar from a Super Duty, or even a bar from a stock 4WD Excursion should be a nice addition.
If you're going to consider an RAS, you might want to give the LandYot Radius Rods a look as well. Weigh your options and determine which fits your needs best.
If you really want a new suspension, get the parts for a 2011 2WD Super Duty or even an 08-10 Super Duty ...(Front coils, new rear shackles, and rear springs). The rear leafs are 8 inches longer and will greatly improve the suspension. This thread has more info on this: https://www.ford-trucks.com/forums/9...onversion.html
Perhaps you can even get custom made springs from these guys: Deaver Suspension
Go over all your options and pick and choose what you need. You can combine any of what I mentioned together to create exactly what you want.
Old Jun 12, 2011 | 08:26 AM
FourXFords's Avatar
FourXFords
Thanks, I guess I have to start looking for springs for the front at least. anyone got some front coils?
Sounds like RAS will make the rear better too, How long a project is that? Any recommednations on place to get a good deal?
Old Jun 13, 2011 | 06:34 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Your ball joints may be worn causing the camber problem. On my f250 2wd I replaced them and they have a camber adjuster that goes on top of the upper ball joint that you can buy most parts places.
Old Jun 16, 2011 | 09:09 AM
FourXFords's Avatar
FourXFords
Ball joints and/or new f250 springs
Relpacing ball joints is a home job?
Front spring replacement tips? or just as easy as it sounds
Anybody else have 2WD front sag suggestions for 7.3?
What about air bags like on RV
Thanks for any responses, just gotta sell the wife on upgrades for her ride so it doesn't ride like a Uhaul truck.
Old Jun 16, 2011 | 03:55 PM
FourXFords's Avatar
FourXFords
Look what I found
Procomp
stock height
2wd
direct replacement springs
PN E3724615
Pro Comp Coil Springs - Low Price Guarantee
Old Sep 30, 2011 | 10:29 AM
Joe28443's Avatar
Joe28443
Joe28443
Did you ever get these?
00X7.3PSD
Apr 1, 2014 02:51 PM
fstbk65
Jul 16, 2012 06:00 AM
b0lingball
Dec 7, 2011 06:26 PM
speed
Jul 12, 2011 12:51 AM
4griffins
Dec 30, 2009 11:47 AM
