Help- No start, low batteries **Solved**
Old Jun 10, 2011 | 10:35 AM
locknload223's Avatar
locknload223
Thanks everyone. I'm at AZ now, they just swapped out both batteries. I had the kid load test the better one on the truck, unhooked of course, and it dropped a little so he said he swap it too. I just metered it running and I'm at 14 volts.
Old Jun 10, 2011 | 10:44 AM
cj45lc's Avatar
cj45lc
Good deal Mike, have a great trip
Old Jun 10, 2011 | 10:59 AM
locknload223
Thanks again everyone, this place effin' rocks. When in a time crunch you all came through, once again. I'm really surprised AZ was so easy to warranty, I've read about other's experience and usually a store will want to charge it up then load test it. My guy was either new or nice, either way, I'm up to 14 volts and have a little more time to decide what I want to do about my alt. I'm sure it's original and want to replace it before I'm stranded on the side of the road. We have a lot of road trips planned out this year. I want to look into having a shop go through it opposed to a parts house.
Thanks again, I'll toast you all tonight with a New Castle and cigar.
Old Jun 10, 2011 | 11:11 AM
Duck Hunter81's Avatar
Duck Hunter81
Thats great that they swapped out both. Happened to me a couple years ago and they would only swap my 1 bad battery. # months late the other old one died and was now out of warranty. Bought 2 new ones from Sams club and have a good spare now.
Old Jun 10, 2011 | 11:59 AM
Crewcab Turbo's Avatar
Crewcab Turbo
I believe i read somewhere on this site that the computer controlls the voltage regulator.The computer probably saw the bad battery and shut off the charging for safety, your alt may be just fine.
Old Jun 10, 2011 | 12:04 PM
SpringerPop's Avatar
SpringerPop
That is incorrect.
There are SOME Ford products where that's how it works, but our SuperDutys (99's - 03's) have an internal regulator that senses off the battery buss, and is not dependent on the PCM at all for field reference.
Google something like "Ford 6G gray regulator" and read up. We use the GRAY/GRAY regulator, but there are many different colors in the Ford line-up, all doing different things. Some even delay when the alternator begins charging. Fortunately, ours are relatively simple to diagnose and test.
Pop
Old Jun 10, 2011 | 12:32 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Have a great trip!!
Old Jun 10, 2011 | 02:04 PM
Brother Les's Avatar
Brother Les
Two new Batts and a New Alt?
Get one of those 'plug-in' volt gauges and you would have seen this coming before it left you with a problem.
Old Jun 10, 2011 | 02:07 PM
Brother Les
If you are pushing 14 volts 'NOW' then your Alt is fine.... your Batts should only get up to 'around' 12.5 v by themselves.... anything over that is pushed in by the Alt. and the Batts will settle back to 12.5 v when the truck is shut off. Sounds like a short in the batts and they would not take anymore.
Old Jun 10, 2011 | 02:09 PM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Glad you got your rig up and running!
Old Jun 10, 2011 | 07:34 PM
locknload223
Got a nice corner spot and we just finished some tacos. Thanks again guys, have a great weekend.
Old Jun 10, 2011 | 07:36 PM
Crewcab Turbo
Looks like u made it, have fun!
Old Jun 10, 2011 | 07:42 PM
  #28
cj45lc's Avatar
cj45lc
Glad you got it straightened out Mike
Have a great weekend
Rusty Axlerod
Feb 28, 2023 11:19 AM
AmericanMade
19
Jul 24, 2015 07:08 PM
mechelement
Jan 14, 2013 08:26 AM
countryboy8085
19
Dec 4, 2012 11:00 PM
allegedgenius
Jun 5, 2011 02:21 PM
