Compatibility of brackets
Old Mar 26, 2003 | 05:19 AM
77460ford's Avatar
77460ford
I'm piecing together the parts for the brake upgrade found in the tech section. Everything is going well for part collection but for one piece. My '77 uses the higher mounted brake booster and "Z" linkage. I can buy a new booster and M/C but not this bracket. For anyone who has put this together can you tell me if the bracket I have on my F150 fit the F350 booster or can be made to fit it? Thanks for your help.
John.
Old Mar 26, 2003 | 11:21 AM
GeneStoner's Avatar
GeneStoner
It will "Fit" (bolt pattern), but the MC rod will not properly align with the pedal cluster. Since the brackets are shorter than the f350 ones, the rod will protrude through the firewall too far.
The brackets you need are the ones with holes in the sides.
-Wording edited for content, see guidelines:-
