Yep, it must be something you did. Check all the connections, make sure they are clean and solid. Make sure you used the correct replacement bulbs. Do the guages work? What about the dash lights?
Just for Craps & Giggles, I replaced the headlight switch to see if maybe the rheostat was shot, (or perhaps something else related to the switch was causing the problem) but no dice.
All connections look good, brand new bulbs, printed circuit looks good, gauges work, just no dash lights.
Is there a ground strap somewhere that I should be looking for???
PS. I DO get a light lighting up the windshield wiper and light switch. Just no gauges...
