Head Bolts
Old Mar 26, 2003 | 01:45 AM
erikl85's Avatar
erikl85
Head Bolts
When I got my pushrod guideplate conversion kit, I remember reading something about needing some kind of special head bolts because you cannot access the bolt head with a torque wrench, I cannot remember what kind of bolts that would be, anyone?
Old Mar 26, 2003 | 01:24 PM
georgedavila's Avatar
georgedavila
Head Bolts
Torque the heads before you install the rocker assemblies. I haven't heard of a special bolt. With head bolt torque values at 130-140ftlb, you'll have to get a torque wrench on them.
Old Mar 28, 2003 | 10:11 PM
erikl85's Avatar
erikl85
Head Bolts
The instructions say use half inch by 4 or 4.5 inch allen head bolts.
Old Mar 29, 2003 | 12:47 AM
merc460's Avatar
merc460
Head Bolts
I am with George on this one all head bolts are torqued before rocker arms are installed. Who made the conversion kit??
Eric
Old Mar 29, 2003 | 03:16 AM
erikl85's Avatar
erikl85
Head Bolts
It was a crane cams pushrod guideplate conversion kit.
Old Mar 29, 2003 | 03:51 AM
erikl85's Avatar
erikl85
Head Bolts
Here is the link http://64.90.9.168/cranecams/pdf/301g.pdf, it is the second bold title down. "Special instructions for cylinder head bolts".
Old Mar 29, 2003 | 07:51 AM
georgedavila
Head Bolts
They say to use the Allen bolts because regular head bolts on the top row will not clear the guideplates for R&R of the heads after the guideplates are installed.
That's fine for the original installation, you can use an Allen head socket with the torque wrench, but how would you torque them down with the guideplates in place if you did have to remove and replace the heads for say a burned valve?
They're also instructing you to use thread locker with a four-hour drying time on the studs. I've never used thread locker on studs, just a lubricant, but that shouldn't hurt anything.
To me, it sounds like once you have the guideplates installed, they're not to be removed for any reason.
Old Mar 29, 2003 | 03:23 PM
erikl85's Avatar
erikl85
Head Bolts
Do you have any idea where I can get these bolts?
Old Mar 29, 2003 | 07:46 PM
georgedavila
Head Bolts
Never bought any that big. Do a web search.
Old Mar 29, 2003 | 09:12 PM
Mil1ion's Avatar
Mil1ion
Head Bolts
Which Bolts do you mean Eric?
The original or the Allen bolts.
Old Mar 30, 2003 | 01:06 AM
erikl85's Avatar
erikl85
Head Bolts
Allen Bolts.
Old Mar 31, 2003 | 08:31 AM
georgedavila
Head Bolts
I'd do a web search or your local machine shop can order them for you, but that'll be expensive.
Old Mar 31, 2003 | 07:23 PM
erikl85's Avatar
erikl85
Head Bolts
What would you suggest I search for? Anything that I tried did not return anything helpful. I just tried napa and they can special order them for 226$, I don't think so.
Old Mar 31, 2003 | 07:33 PM
merc460's Avatar
merc460
Head Bolts
You should try a local bolt supply house, just make sure that the bolts are at least grade 8 or higher. Eric
Old Mar 31, 2003 | 11:03 PM
erikl85's Avatar
erikl85
Head Bolts
Hmmm I dont think we have a bolt supply house here, are there any chains of stores? I might be able to go to a town south of here which has a relativley large population (80,000), what would the type of store be to look up in the phone book?
