55F100 modified frame
Old 06-08-2011, 09:48 AM
CdnWillyG's Avatar
CdnWillyG
CdnWillyG is offline
I need the goods on this topic.
In another thread here there was a clearance issue withthe exhaust and the original motor mount crossmember located under the firewall and the advise was not to mess with it.
On my frame this has been removed and is running a boxed Mustang ll IFS with a support installed to hold the T5 tranny.
Looking at other modified frames on this site and new repo frames this crossmember has been removed or not installed.
I guess my question is it okay to leave this out?
Old 06-08-2011, 09:55 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,467 Likes on 1,407 Posts
IMHO, in your case, you are fine. The MII crossmember and boxing takes the place structurally of the original crossmember removed. You've changed the load dynamics to that of a modern vehicle, and you should have no troubles. I'll also add that in your pic, it looks like yours is done better than most. Nice job.
Old 06-08-2011, 09:59 AM
Okiedokie's Avatar
Okiedokie
Okiedokie is offline
Boxed mine back to the cab mounts. No problems. Nice looking frame.
Old 06-08-2011, 07:02 PM
CdnWillyG's Avatar
CdnWillyG
That's good news and what I was hoping would be the answer.
Not sure how successful I would have been trying to find that crossmember.
Thanks for the comments on the frame.
Old 06-09-2011, 09:57 AM
thepitshop's Avatar
thepitshop
thepitshop is offline
frame`s looking good! i`d remove the crossmember
Old 06-09-2011, 10:04 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
The original crossmember counteracts the rotational forces applied to the frame by the front cab mounts. It was by design not chance that this crossmember was placed in line with the front cab mounts. If you can stand on the cab mount "wing" and there is no flex in the frame at that point then you should be OK.
Old 06-10-2011, 01:05 AM
CdnWillyG's Avatar
CdnWillyG
Thanks for the input!
I will move on with the build...back to getting the doors straight and the gaps even.
tubolove
05-16-2010 09:23 AM
AZAV8
20
10-30-2009 02:12 PM
93Mule
1978 - 1996 Big Bronco
08-22-2007 01:22 PM
52'F-3
05-10-2007 09:01 PM
jaymoford
10-07-2004 08:54 PM
Quick Reply: 55F100 modified frame
