AC/Heat Not working, possible PCM problem...?
Driving to one of my clients, everything was working fine. When I left there was no A/C. I checked coolant, fuses, etc with no luck. We had a bit of a cold-snap and I also found out my heater didnt work. Air comes out of the vents, but it's all panel air, regardless of temp or control settings.
Took it to a mechanic who said the high-pressure switch was dirty, he cleaned it and the A/C worked at the shop. The moment I left the exact same problems started happening again. It's been back to the same mechanic, and today he tells me that the a/c clutch is drawing to many amps and shorting it out, at which point the PCM tells it to goto hell. He can get it working by resetting the computer, however, the moment I put it in gear it stops working (a/c, heat, all of it). He was able to put power directly to it and it run with no problems.
To me (very little mechanical knowledge) it seems like power, or the condensor. The mechanic said that the heat going out isn't related at all, which makes no sense to me because it's happened there in his shop where the heat will only work if the a/c works. Hes telling me I need either a new clutch or a new compressor altogether. Quoted me 300 and 1000 for each respectively.
Does any of this sound right or has someone else had a similar problem?
Side-Note: The morning of the day when the a/c initially broke, my car turned off suddenly while driving. I was in gear and driving down the road like normal. I popped the clutch, turned the key and it started right back up. Also, cruise control seems to have stopped working and the eft blinker. If i hold the lever down (like push an extra 2cm) it comes on and works. It is sporadic.
If the general consensus is that my mechanic is correct and the A/C clutch is pulling to many amps, then I'll get that replaced.
I suspect you have two simultaneous faults and the mechanic can't sort it out.
I appreciate all the help. I think this weekend I'll take it to somewhere like Midas to have them diagnosis it (not necessarily fix, since they are way over-priced).
Got it fixed. After everything it appears to have been a fuse :\
I am not sure what the original problem was (very well could have been the high pressure switch as well as the fuse) but the eventual fix was replacing fuse #5(Speed Control Module, Reverse Lamp, Climate Mode Switch(bingo), Daytime Running Lamp Relay) underneath the dash. From what I can gather the mechanic replaced that fuse with a 30amp amp fuse, which also blew. Once I replace the 30amp with a 15, everything worked.
Story on how I found out:
I went to a store today to pickup a birthday gift for my brother and as I was backing out the car behind me pulled up to let me know my reverse lights were out. So after I got home I decided to read each fuse description, rather than just skimming for what I was looking for, and check the ones that seemed relevant.
In my original posting I mentioned that my cruise had gone out, but couldn't be certain if it was at the same time as my a/c, and when I looked for "cruise control" fuses, I found nothing. Well, reading the fuse descriptions, I realized Ford called it "Speed Control". So I checked all of the fuses related to speed control, pcm, and a/c. The #5 fuse had a 30amp, non-stock fuse which was blown. I replaced it and viola.
I knew the mechanic was crap when I took it to him the first time. He told me my battery was bad because he had to start it from the solenoid twice. He had it running when I arrived so I just drove it straight home. Once I was home, I tried to start it and got nothing. I checked the fuses then and realized he had taken out and left on the floor mat my clutch switch fuse (#20). Replacing it started the truck right up.
Experience gained? Never trust a mechanic you've never worked with before, and also do your due diligence when it comes to checking the things that should be quick, easy fixes.
