Sponsored by: Kumho
Dana44 death wobble?
Old Jun 7, 2011 | 02:58 PM
MonsterTruck\m/'s Avatar
MonsterTruck\m/
I have a 68 bronco with a D44 frount end. It has a front disc break conversion. I was driving when all of a sudden it started to wobble and make a lot of noise, the hub also go really hot. After it cooled i pulled the Hub and saw that it was torn to ****. All the gears for the Hub were stripped, So i put in a new hub (same make and model hub) and now when i put it all on the axle and tighten it down the rotor and hub still feel loose on the axle, the other side of the axle seems a lot firmer, any ideas?
Old Jun 7, 2011 | 03:42 PM
Lazy K's Avatar
Lazy K
Sounds like you need new wheel bearings on that side or at least adjusted up.
Old Jun 19, 2011 | 02:42 AM
68Shortbox5.4's Avatar
68Shortbox5.4
Also make sure none of your bolts came loose that bolt your spindle to your steering knuckle, or that your spindle was damaged
