Thanks....
Old Jun 6, 2011 | 03:32 PM
Tampa250's Avatar
Tampa250
Thanks....
I was just sitting here cruising the forum and thought I would take a moment and thank you guys for all the valuable advice I've received here recently. I've been a member here for almost 7 years, and came in here on a Saturday about a month ago to figure out why I had oil in my coolant. I received very timely and helpful responses that set me on a course to correct the problem.
I've owned this truck since new and have always kept up on maintenance but never took to this site in the obsessive way that I have as of late. Within the last month I've: installed a full Bulletproof kit with remote oil cooler, upgraded EGR cooler and bypass oil filtration along with a Dieselsite coolant filter kit, blue fuel pressure spring upgrade, added the Edge Insight CTS to supplement the 3 Autometer gauges I've had for years, replaced my Diablosport Predator with a SCT with Matt's SRL tune, added the MBRP cat delete pipe to the 4" system I've had for years, installed a pair of DieHard Platinum batteries, exchanged the Ford Gold coolant for Zerex's Cat-approved formula, and begun using Power Service Diesel Kleen grey bottle at fill-ups.
In short, I've learned a lot here over the years but the last month has been a huge advancement for my understanding of my 6.0. I just wanted to say THANK YOU to those of you that have provided some valuable advice to me- I won't name names because I am sure I would leave someone out. Hopefully I will be able to step in and pay if forward and help someone else...
Last edited by Tampa250; Jun 7, 2011 at 11:59 AM. Reason: Forgot the new batteries and the blue spring upgrade!
Old Jun 6, 2011 | 07:50 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
I'll second that!!!
Old Jun 7, 2011 | 06:29 AM
npccpartsman's Avatar
npccpartsman
Originally Posted by Tampa250
......Hopefully I will be able to step in and pay if forward and help someone else...
And that's what it's REALLY all about
Old Jun 7, 2011 | 10:35 AM
NewToDiesels's Avatar
NewToDiesels
Agreed. I've done a Bulletproof oil cooler and EGR upgrade. Scanguage II and blue spring install just by combing through threads. I do appreciate the help from all you guys.
2004 F250 Lariat 2WD 151,000 miles and counting
Old Jun 7, 2011 | 10:52 AM
Misky6.0's Avatar
Misky6.0
same here, every mod was done because of this site
and the knowledge it provides.
Old Jun 7, 2011 | 11:59 AM
Tampa250's Avatar
Tampa250
You just reminded me that I also did the blue spring upgrade this past month!
