Receiver Hitch
Old Jun 6, 2011 | 03:07 PM
73FordF100's Avatar
73FordF100
Receiver Hitch
I'm looking at buying a receiver hitch for my truck so I can tow again. Anybody know where I can find one for under $100 or what other years might work?
I used to tow with the ugly step bumper it had on it when I got it. It had this bolted under the bumper:
It seemed to work ok and I was considering using it again but I don't want to drill into my decent original chrome bumper I got for my truck. I was thinking of fabbing something up to bolt to the chassis using this. The only problem is my dad and I don't really have any skills in welding and we want to do it right and not crappily. The question is, should I buy one (if I can find one under $100) or try to fab up something? I found one off a 84 and another off a 90 something F-150; could these work? Thanks.
Old Jun 6, 2011 | 05:37 PM
HIO Silver's Avatar
HIO Silver
I hated the heavy and ugly dock bumper and installed a contour bumper. Ahhhhhhh.......
I was in the same boat as you wanting to tow! I measured my frame and went hunting in the 'yards. I got my bolt-on, frame-mounted Class III hitch off the rotting carcass of a late 80s/early 90s Bronco... drilled six holes for new Grade 8 hardware and 1/4 backing plates (to spread the load) and she was good to go.
Cost? The hitch wouldda been $46 but it was half-off day at the 'yard. Serendipity! Total cost was like $30 with the new hardware. BTW, get them nylon-lined locking nuts.
Old Jun 6, 2011 | 07:49 PM
akforceten's Avatar
akforceten
I got mine off of a 96 dodge 4x4 truck at the wrecking yard where i work.
i had to drill the holes in the frame.
Old Jun 6, 2011 | 07:50 PM
97oneton's Avatar
97oneton
do not use that cheesy hitch adapter crap.
what do you plan on towing?what does it weigh(load)?
73FordF100's Avatar
73FordF100
Yeah I love the contoured bumper so much more! Thanks for the advice! So I will look for a 80s-90s F-150-Bronco for a hitch. Hopefully this weekend I'll be able to go to the junkyard and look for one, they have a couple dentsides there; hopefully one that has a hitch!
Old Jun 6, 2011 | 07:54 PM
73FordF100's Avatar
73FordF100
I don't plan to tow anything super heavy but if I had to, I want to have the capability to do so.
Old Jun 6, 2011 | 08:04 PM
97oneton's Avatar
97oneton
a 74-87 1/2,3/4,1 ton and 88-91 vent window door gm truck, blazer,or suburban's frame rails are same distance apart(i know gm) one off of them could work also.don't use a dodge hitch,they bend easier than the gm or ford's.
some 92+ gm's use a straight tube with welded plates that bolt to frame.cut the weld around the square tube,slide the plate in a to match your frame rails and reweld it,have done this with our bog trucks before.
Old Jun 6, 2011 | 08:15 PM
akforceten's Avatar
akforceten
The dodge hitch I have is very strong and DOES NOT BEND! The one I found is thicker an better built than anything on a chevy ! The one is a class 5 hitch can tow 10,000 pound rv trailer with it.
Old Jun 6, 2011 | 08:32 PM
MiddleNameMUD's Avatar
MiddleNameMUD
WOW!!! Someone's a lil cranky... Need a hug fella??
Old Jun 6, 2011 | 09:44 PM
73f250highboy's Avatar
73f250highboy
HAHAHAHAHAHAH!!!!!!!!!!
Old Jun 6, 2011 | 10:31 PM
CalebJns's Avatar
CalebJns
I just took the one off of my '98 Jeep Grand Cherokee...I haven't put it on my '78 as of yet, but from dry fitting on a spare frame, it looks like it will bolt right up...may have to drill two holes, but looks really close...Currently I have a tow "bar"??? I am not sure if it was homemade or some type of aftermarket item...it was on the truck when I purchased it...but it attaches to the frame rails, and come out below my contour bumper...it ISN'T a square tube, but just a 2" ball...I can get some pics tomorrow if you want...
Old Jun 6, 2011 | 10:50 PM
IZZYAZ's Avatar
IZZYAZ
I actually got one from Cabelas a year or so back. They had free shipping and the hitch was on sale. I paid just over $100 shipped to my door for a bolt on brand new hitch. If I remember right I had to drill 2 holes, but my time was worth the little extra I had to Patti get something that bolted up with little work.
monsterbaby
All Things Towing
Jan 4, 2016 06:23 PM
351Cleveland C4
20
Mar 3, 2015 08:17 PM
mofoco1
15
Mar 7, 2014 05:05 PM
1975FordF250
Feb 10, 2014 06:56 PM
turborich
Mar 20, 2012 06:41 PM
